Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › image management
- This topic has 4 replies, 3 voices, and was last updated 5 years, 10 months ago by
Jamie O’Reilly.
- September 30, 2019 at 7:49 pm #84556
Jamie O’Reilly
We’re planning to launch our marketplace in a few weeks and I’m a bit concerned about the management of images once we have several hundred or even thousand vendors each with hundreds of products. As an admin I would ideally be able to go to the media manager and see a filing system with folders for each of the vendors stores – with their images other folders for the website more generally. I’m worried that if we don’t do this at the beginning the media manager would soon become chaotic. I know there are plugins out there where I can create folders in my media manager but I don’t know how we would have a folder set up for any associated store. Please can you advise?
Jamie
- October 9, 2019 at 1:27 am #85732
Jamie O’Reilly
ParticipantI’ve added a media folders plugin which seems to help us keep our website images separate to an extent from store images which is helpful. No need for further assistance with this. Thanks
- October 9, 2019 at 2:07 pm #85800
kaloomee
ParticipantHI Jamie O’Reilly
Would you be so kind as to name the ‘Media folders’ plugin that you have used please
I am sure that this would help other users
Kaloomee - October 9, 2019 at 5:19 pm #85831
sdel_nevo
ParticipantHi Jamie
that plugin sounds interesting, would you be able to post here what you used
Steve
- October 11, 2019 at 1:43 am #86142
Jamie O’Reilly
I tried Filebird and thought it was a great solution but unfortunately, I found that vendors were able to create folders as well and access folders that other vendors had created – argh. Had to deactivate it quickly. I did ask the plugin maker if there was any way that access to the folders could be restricted to a specific user level eg admin but they said that was not currently possible so at the moment I still don’t have a solution. Interested to hear from anyone else on something that might work.
Jamie
- The topic ‘image management’ is closed to new replies.
