Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › implement a better search of categories and sub categories for sellers
- This topic has 5 replies, 2 voices, and was last updated 7 years, 10 months ago by
- December 24, 2018 at 9:15 pm #41003
pablo
GuestHello!. I see you have improved a lot since the last time I installed your marketplace to test it.
but they still have a big problem when you need a multi-vendor site.
your system of selecting categories for the seller to publish your product, is very basic.
in multi-vendor sites requires an important tree of categories and sub categories that can not be left in the hands of sellers. need to improve the search system of categories in the front end. The seller should be able to enter three letters and that the system provides the categories that match your search. dokan does this quite well.
Do you think you could upgrade with this modification?thanks!!
- December 25, 2018 at 5:51 am #41029
Well, WCFM has bit the options. Tweak this setting option from WCFM Admin setting – https://ibb.co/KNHPRQT
You may also try this custom addon for improved category selection – https://drive.google.com/file/d/1VBvBiDk0tbl-jokSlaKjIxggYKr_2DTh/view?usp=sharing
- December 25, 2018 at 7:26 pm #41107
pablo
Guestok. thank you for your reply. all those files.? should i replace the original files inside the front end wcfm folder?
What happens when I update wcfm with a new version?thank you!
- December 26, 2018 at 5:27 am #41147
I have send you a custom addon/plugin.
Just install that to your site as other plugins.
Please never edit any WCFM or it’s addons core files.
Regular updates are really important.Thank You
- December 26, 2018 at 5:35 pm #41236
pablo
Guestoooohhh!!..ok..Thank you so much!. I’ll try it and then I’ll tell you how it worked.
- December 26, 2018 at 5:54 pm #41238
MemberYou are welcome 🙂
- The topic ‘implement a better search of categories and sub categories for sellers’ is closed to new replies.
