Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Import CSV
- This topic has 6 replies, 2 voices, and was last updated 5 years, 7 months ago by
Steven Kuijpers.
- December 6, 2019 at 6:05 pm #96260
Steven Kuijpers
ParticipantI would like to give my shop owners some more options using the CSV uploader. There are a bunch of plugins available, but they don’t work with WCFM, because it falls back to the default Woocommerce upload option.
Is there a compatible plugin for this or is there some other way to influence this?
Two things I am looking for:
1. The head of a column (Cell 1) should be mapped to a ACF field. Example:
Column: Allergies
First product the cell beneath it says: Peanuts
Second product the cell is empty
Third product the cell says: Dairy, EggsSo every product has a specification of Allergy: xxx. The first product has to show Peanuts behind it. The second one should be empty. The third one should be read Dairy and Milk.
2. (optional) I would like to map out the fields and set them for the shop owner. So if I tell the system that a certain column labelled Allergies is to map with Allergy, it is automatically selected during the mapping.
- December 7, 2019 at 2:25 pm #96443
– Well, WCFM also use WooCommerce default import engine. SO, if any plugin support WooCommerce default importer then that will supported by WCFM as well.
- December 11, 2019 at 9:42 pm #97075
Steven Kuijpers
ParticipantThank you for your quick reply! For what I can see, all the main extended importer plugins work separately from the woocommerce one by default. I have (bought and) checked:
https://www.webtoffee.com/product/product-import-export-woocommerce/
https://woocommerce.com/products/product-csv-import-suite
https://www.wpallimport.com/But the Store Owners keep getting the regular Woocommerce import CSV screen when I have activated these plugins.
Any idea on which plugin I can use that does work with the default importer and extends it?
Thank you in advance for you reply.
- December 24, 2019 at 11:29 am #98907
MemberSorry, these are not supported for vendors.
You may import products as Admin using those and then bulk assign to vendors.
- December 24, 2019 at 8:26 pm #99010
Steven Kuijpers
ParticipantYes I noticed. But my vendors need to upload their products themselves, not through Admin. If I need to do it as admin it might cost me hours per day. We’ll have a lot of Store Vendors that update their prices and other attributes more than daily. Most of our store has fresh food products.
Is there an option or a plugin that does allow Store vendors to upload the csv themseleves and get them more options to do so?
- December 28, 2019 at 12:00 pm #99698
Do you have tried WCFM Ultimate existing “Product Importer”?
If so, what is missing there for you?
- December 30, 2019 at 2:42 pm #100017
Steven Kuijpers
ParticipantDo you mean the uploader in the market environment, which is actually the Woocommerce csv upload? Or is there a different one that I am missing?
Well, we are having Vendors sell products that have quite a lot of specifications, like allergies, ingredients, product good until dates, etc. So they use a csv with in every column the specific information for that product. When they import that, it should match up with the ACF plugin fields that I have created for them. In that way we can autofilter the content of all vendors on the frontend.
Now when they upload the need to match their input with the fields available within woocommerce, which can be quite confusing and needs extra columns in their csv to work.
- The topic ‘Import CSV’ is closed to new replies.
