Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Incorrect Shipping Charges and Stripe Split Pay Commission Calculation
- This topic has 28 replies, 2 voices, and was last updated 6 years, 5 months ago by
Sean Mac.
- February 22, 2019 at 12:35 am #49450
Sean Mac
ParticipantHi!
I am having the following two issues with vendor order total calculations:
1. For some strange reason, the shipping cost is always off by one cent. The admin dashboard displays the correct amount but vendor dashboard is different. I know this may not be a big issue but it could lead to bigger problems later on (Please see the first 2 screenshots for examples)
2. The marketplace commissions is set for 6% to the admin (screenshot 3) but when the order goes to stripe, the application fee is incorrect (screenshot 4)I have not changed my marketplace settings so I have no idea where this issue is coming from. Also, all of my plugins are up to date.
You must be logged in to view attached files. - February 23, 2019 at 1:16 pm #49706
*** This is round of issue, we will take care of this.
*** Please setup commission in reverse way and take a look, Vendor Commission 94%
- February 23, 2019 at 9:30 pm #49755
Sean Mac
Participant*** Please setup commission in reverse way and take a look, Vendor Commission 94%
Thanks for your assistance but unfortunately that didn’t work for me either. I did try the commission settings “By Vendor Sales” and “Percent + Fixed”. Those settings worked successfully but ONLY if there was 1 item in the order. If there is more than one item (vendors sell products and appointments) in a single order, the commissions are not applied to the total order correctly. The fee amount displays correctly in the marketplace admin and vendor dashboard but it is still incorrectly distributed in the Stripe dashboard.
- February 25, 2019 at 6:16 am #49923
– All are vendor products, or Admin product is also there?Which Stripe charge setting you are using?
- February 25, 2019 at 5:07 pm #50020
Sean Mac
ParticipantAll the products on the site are vendor products.
Since the most recent update of WCFM plugins, I’m using “Percent + Fixed”. This is the only commission setting that works successfully for my site with products and appointments in the total order.
The Stripe charge settings are configured for “Direct charges”.
You must be logged in to view attached files. - February 26, 2019 at 5:35 am #50103
– Keep commission setting in “vendor Mode”
- March 11, 2019 at 10:55 pm #52156
Sean Mac
Just wanted to revisit this thread and inform you that you I am still having an issue with multiple appointments in the cart. No matter how many appointments are in the cart/order (even if all the appointments are by the same vendor), the vendor dashboard only shows 1 item purchased.
I’ve been testing this most of the day and it looks like only the first item in the cart is being recognized. My Stripe dashboard and the test vendor dashboard displays the correct commission amount but the WCFM vendor dashboard is only showing that the customer purchased 1 item.
- March 12, 2019 at 5:04 am #52189
It’s matter of commission calculation or no. of item display?
Hope you are using Stripe Split pay?
If it’s commission calculation issue, then update WCFM Marketplace to 2.2.4 and take a look.
- March 12, 2019 at 12:11 pm #52264
Sean Mac
ParticipantThis is a matter of number of items purchased and yes, I am using Stripe Split pay.
- March 12, 2019 at 2:18 pm #52278
Are you adding same appointment product multiple time in cart with different time slots?
- March 12, 2019 at 2:18 pm #52279
MemberCan you please show me cart and vendor’s order details screenshot?
- March 12, 2019 at 4:10 pm #52305
Sean Mac
ParticipantBelow are screenshots of a customer order for 3 different appointments by the same vendor – different days, different times. Once the order is processed, the Stripe Split payment is distributed correctly but the vendor’s dashboard displays only 1 item was purchased.
You must be logged in to view attached files. - March 12, 2019 at 5:14 pm #52318
Please show me order details screenshot for this order from Admin and Vendor dashboard.
- March 12, 2019 at 5:45 pm #52322
- March 13, 2019 at 4:42 am #52369
MemberStrange!
Well, what is your WCFM and it’s addons versions?
Do you have any custom add or code related to vendor orders?
- March 14, 2019 at 3:25 pm #52620
Sean Mac
ParticipantI apologize for the late response; I’ve been doing quite a bit of testing trying to get to the bottom of this problem.
I just created a fresh wordpress install and uploaded ONLY the following 5 plugins:
WooCommerce 3.5.6
WooCommerce Appointments 4.3.5
WooCommerce Frontend Manager 5.4.4
WooCommerce Frontend Manager Ultimate 5.4.4
WooCommerce Multivendor Marketplace 2.2.4I did a test order for 2 appointments – different days, different times. The problem still persists. The vendor dashboard still only shows 1 (one) item was purchased. I have no idea why this is happening.
- March 15, 2019 at 5:18 am #52765
That’s quite strange! We are checking this as well.
One thing, using which type user you have placed the order, is that also a vendor user?
- March 15, 2019 at 1:22 pm #52835
Sean Mac
ParticipantThey were customer user orders.
- March 16, 2019 at 9:27 am #52947
MemberOK, we are checking this!
- March 16, 2019 at 9:28 am #52948
MemberBetween, as Admin are you able to see all Appointments under WCFM Order details?
- March 16, 2019 at 3:29 pm #53005
Sean Mac
ParticipantYes, as admin I am able to see all appointments under order details.
- March 17, 2019 at 7:09 am #53070
I have just this again but failed to generate, please check this – https://www.useloom.com/share/2d90fca86e324ad4af1482ead3b5ab01
Are you doing something else!
- March 19, 2019 at 2:26 pm #53507
Sean Mac
ParticipantThank you very much for the video demonstration. Based on the video, you and I know are doing the same thing but for some strange reason I’m getting a different result. I have no idea what the issue is. There are only 5 plugins installed and its running on the WordPress Twenty Nineteen theme. There are no customizations whatsoever. Even after updating the WCFM plugins to 5.4.5, the problem still persists.
- March 19, 2019 at 2:33 pm #53511
Sean Mac
ParticipantThis reply has been marked as private. - March 22, 2019 at 1:24 pm #54001
Sean Mac
Can someone please help me?
- March 23, 2019 at 1:11 pm #54206
MemberJust relax, we are checking this.
- March 23, 2019 at 2:36 pm #54218
Sean Mac
ParticipantThank you very much!
- March 26, 2019 at 12:09 pm #54535
MemberIt’s resolved! Please check now.
- March 26, 2019 at 1:17 pm #54551
Sean Mac
ParticipantIT WORKS CORRECTLY! Thank you so very much!
- The topic ‘Incorrect Shipping Charges and Stripe Split Pay Commission Calculation’ is closed to new replies.
