Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Inquiry confirmation freeze
- This topic has 6 replies, 2 voices, and was last updated 5 years, 2 months ago by
Bernard Prince.
- May 10, 2020 at 7:23 pm #129239
Bernard Prince
I’ve installed the inquiry button option. When i made a request to send button, the popup freeze (with the little GIF running indefinitely) and the notification email are never received. However, the request appears in the vendor dashboard.Any idea why?
- May 11, 2020 at 12:58 pm #129464
Sarmistha Chakraborty
It seems’s like this is happening due to some plugin conflict. Kindly disable all other plugins except WooCommerce and WCFM plugins. After that you can enable rest of the plugins one by one to find out the cause.
Let me know how it goes.Thanks!
- May 13, 2020 at 4:40 pm #130400
Bernard Prince
Thanks for the suggestion. After deactivate all plugins as suggested, the problem remain. But now I see this error in the console:VM3603:1 Uncaught SyntaxError: Unexpected token < in JSON at position 0
at JSON.parse (<anonymous>)
at Function.n.parseJSON (jquery.js?ver=1.12.4-wp:4)
at Function.a.parseJSON (jquery-migrate.min.js?ver=1.4.1:2)
at Object.success (wcfm-script-enquiry-tab.js?ver=6.4.9:15)
at i (jquery.js?ver=1.12.4-wp:2)
at Object.fireWith [as resolveWith] (jquery.js?ver=1.12.4-wp:2)
at x (jquery.js?ver=1.12.4-wp:4)
at XMLHttpRequest.c (jquery.js?ver=1.12.4-wp:4)Also, the error now seems to be only on Google Chrome, message is sent with Firefox.
- May 13, 2020 at 6:10 pm #130429
Possibly this issue occur due to theme, can you please check once again using default wordpress theme. And make sure your WooCommerce and WCFM plugins are updated(others plugins are deactivated).
Kindly also check at wp-admin -> WooCommerce -> Status ->Logs -> is there any error related to this or not!If you still having same issue then share us your site access with url, we will check your site (Set as private reply)
- May 13, 2020 at 11:42 pm #130598
Bernard Prince
Here’s the log:2020-05-13T10:48:37+00:00 CRITICAL Uncaught Error: Call to a member function get_id() on integer in /home/bprince/public_html/wp-content/plugins/woocommerce-multilingual/inc/class-wcml-emails.php:395
Stack trace:
#0 /home/bprince/public_html/wp-content/plugins/woocommerce-multilingual/inc/class-wcml-emails.php(375): WCML_Emails->get_email_translated_string(‘subject’, Object(WCFM_Email_New_enquiry), NULL)
#1 /home/bprince/public_html/wp-includes/class-wp-hook.php(289): WCML_Emails->filter_emails_strings(‘[{site_title}] …’, Object(WCFM_Email_New_enquiry), ‘[{site_title}] …’, ‘subject’)
#2 /home/bprince/public_html/wp-includes/plugin.php(206): WP_Hook->apply_filters(‘[{site_title}] …’, Array)
#3 /home/bprince/public_html/wp-content/plugins/woocommerce/includes/emails/class-wc-email.php(490): apply_filters(‘woocommerce_ema…’, ‘[{site_title}] …’, Object(WCFM_Email_New_enquiry), ‘[{site_title}] …’, ‘subject’, ‘[{site_title}] …’)
#4 /home/bprince/public_html/wp-content/plugins/woocommerce/includes/emails/class-wc-email.php(380): WC_Emai dans /home/bprince/public_html/wp-content/plugins/woocommerce-multilingual/inc/class-wcml-emails.php à la ligne 395It seems related to WPML. But what I don’t understand is that a deactivated all WPML related plug-in after your first suggestion.
- May 14, 2020 at 7:52 pm #130985
Please contact with your WPML plugin support regarding the error.
Have you chance to check “Inquiry confirmation freeze” issue using default wordpress theme and only activated WooCommerce and WCFM plugins( are updated)? The issue is still there? Let us know.Thanks.
- May 26, 2020 at 5:36 pm #135384
Bernard Prince
ParticipantI finally got the solution in WPML forums: https://wpml.org/forums/topic/fatal-error-on-class-wcml-emailsdotphp-line-395/
Thanks your your help!
