Inquiry feature not working
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Inquiry feature not working
Viewing 7 reply threads
    • #119735
      The inquiry feature is not working on my site there is no inquiry tab and if a vendor opens the link to the page than it gives the warning: you dont have permisions to view this page. i have enabled the modules: inquiry and inquiry tab. and i have turned the permision on for inquiry in the capability settings.
      what can i do to fix this problem? thanks
    • #119960
      We assume that you haven’t override the capability from individual vendor/group.
      Do you have created this vendor user using some other multi-vendor plugin previously and now you are using another multi-vendor plugin?
      If so, then you may get this message.
      When you are switching from other some multi-vendor plugin then migration is very important – https://wordpress.org/plugins/wc-multivendor-marketplace-migration/
      Or, create a fresh new vendor user.
      Important – vendor user role should be “Store Vendor”, don’t confuse with previous multi-vendor plugin’s user role!
    • #119974
      I have migrated in the past from Woocommerce Product Vendors to this plugin(all my vendors are “store vendors”). Also successful with the migration plugin. but i don’t think that that is the problem because it is also not working for all the new vendors.
    • #120838
      You have our WCFM Groups&Staff plugin? If so, did you already check in the capability controller of the specific group you created?
    • #120891
      No i don’t have the WCFM Groups&Staff plugin.
    • #121450
      It’s strange.
      Can you share us the site details with site url, we need to debug this issue in your site.(Set as private reply)
    • #122167
      • #122183
        We have logged in your site as a vendor(username: test1vendor), and we can access “Enquiry” dashboard. Please check properly. (PFA)
    • #122201
  • The topic ‘Inquiry feature not working’ is closed to new replies.
