Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Inquiry issues
- This topic has 21 replies, 4 voices, and was last updated 6 years, 5 months ago by
- February 17, 2019 at 6:18 pm #48623
r_guayaquil
ParticipantI have some issues with the inquiry option.
1) When a customer asks an inquiry to a vendor, the vendor can reply but he cannot see what is the customers email. As a vendor where can I see the customers email?
2) When I reply as a vendor, the customer gets an email notification with the answer, but it says that it comes from the admin email account, not from the vendors. So if the customer wants to respond, the admin will receive the email and not the vendor. See image inquiry.jpg
3) When a customer gets the reply in his email account, it says More Details here. As a customer when I click there, it takes me to online store but logged in with the vendors account. Why is that? The customer hasn’t even registered. Is there a way to edit and delete the part that says “More Details here”.
4) Also, I sent two replies as a vendor to the customer, but the customer only got one email. The second email didn’t receive it not even as a spam. See image inquiry1
Thanks a lot for the help!
You must be logged in to view attached files. - February 18, 2019 at 6:57 am #48719
*** Customer email not visible in that way. But vendor may get that from enquiry notification email.
*** Yeah right, emails are triggered from Site Admin email all the time. But vendor may also directly reply from their notification email then it will be from vendor’s own email.
*** Possibly you were previously logged in to the site using vendor account from that browser.
*** Same reply? If so, then mail server and mail client hide those!
- February 18, 2019 at 4:33 pm #48770
r_guayaquil
I just checked and the vendor gets the notification email from the admin, not the customer. So there is no customer email.
Can I change that? The emails can be triggered from vendors email?
I sent 2 different replies to the customer.
Thanks for the help!
- February 18, 2019 at 5:39 pm #48810
*** Customer email in mail CC
*** No, it’s not possible. But you may change email from setting -> https://ibb.co/b68m202
*** Please install this and be sure emails are triggered or not? https://wordpress.org/plugins/wp-mail-logging/
- February 21, 2019 at 1:35 am #49256
Weslley
GuestEu respondo o cliente e chega corretamente as notificações, mas não aparece na aba de respostas do produto.
- February 21, 2019 at 6:50 am #49310
Well, you have to enable this option to make Enquiry reply visible at product page – https://ibb.co/SnHVXGM
- February 23, 2019 at 1:17 am #49599
r_guayaquil
As a suggestion I think it would be better that emails are triggered from vendors email account since the customer is asking directly to a specific vendor.
Hope you can improve the inquiry module.
- February 23, 2019 at 6:59 am #49655
“Hope you can improve the inquiry module.”
*** I am not very sure, will this improve Inquiry module or not! As Vendor already has option to reply directly from their email (From Enquiry Notification email).
But this will reduce site’s security that’s be sure!Thank You
- February 24, 2019 at 11:42 pm #49868
Luke
GuestHi. I’m having an Inquiry-issue.
I used the shortcode [wcfm_inquiry] on Single product page (designed with Elementor).
But when I try the function, the inquiry goes to my account (admin), it doesn’t go to vendor’s account.
I need a solution please.
Thanks in advance !! - February 25, 2019 at 5:30 am #49913
What it’s showing in single product page, a button right?
It’s not opening a popup on-click?
How you are redirect to My Account page?
- February 26, 2019 at 4:46 am #50084
Luke
GuestYes. There’s a button and the pop up opens correctly.
But when the enquiry is sent, it shows on admin’s store manager enquiry dashboard.
The item on the list has the enquiry, product name, customer but no store or vendor name. - February 26, 2019 at 5:40 am #50105
Are you sending Enquiry for a vendor’s product? Or, try from vendor store page!
- March 5, 2019 at 8:20 pm #51244
r_guayaquil
Can I disable the add to cart button for a specific vendor in his products so he can only have available the enquiry button?
- March 6, 2019 at 8:12 am #51322
MemberWell, this only possible if all products from that vendor marked as “Catalog”.
Now, this is possible by custom coding.
- March 17, 2019 at 6:50 pm #53157
r_guayaquil
With the group adn staff add-on i can configure that some vendors can only have available the add to cart button in his products with no enquiry button, and other vendors have only available the enquiry button witn no add to cart button?
- March 18, 2019 at 8:51 am #53215
Sorry, there is no such capability control “Add to Cart” button.
- March 22, 2019 at 1:24 pm #53999
Luke
Hi, i’m sending Enquiry for a vendor’s product. It goes to my wcfm admin dashboard.
The enquiry from vendor store page works fine (goes to vendor’s wcfm dashboard).
I tested it twice with different accounts (not admin) getting the same result.
Help please.
Thanks in advance - March 23, 2019 at 11:09 am #54155
Vendors will receive enquiry for both – Store Query and Vendor’s products query.
Well, we are checking this once again.
- March 30, 2019 at 3:40 am #55288
Jeffs
GuestWell, you have to enable this option to make Enquiry reply visible at product page – https://ibb.co/SnHVXGM
Is there any chance to make the “post to product page” default to enabled ?
Such that every replied is posted on the product page.
Many vendors forgot to check the “enable to product page” hence having to answer one type of questions multiple times.
Can be frustrating. - April 1, 2019 at 5:08 am #55531
Well, Enquiry replies are threaded (many reply possible), do you want to show all those under Products page?
- April 2, 2019 at 6:29 am #55689
Jeffs.north
ParticipantYes . Will like to.
Just that it help save having to answer same questions multiple times over.
If all questions and answers are threaded and visible by default on the product page.
Many users might find answers to their inquiries from previous inquiries answers .
- April 2, 2019 at 6:43 pm #55843
Understand, but Enquiry communication is private between Vendor – Customer.
Open this as Public will not good, atleast we can do this in our plugin’s core. In such case we advise to use any open forum, e.g. BB Press
We have kept “Stick option” for this purpose, so that vendor may mark most appropriate answer as “Stick” and then it will be visible to all.
If you really want to show full communication then we can implement this for you as a custom development.
- The topic ‘Inquiry issues’ is closed to new replies.
