Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Inquiry menu title hook
- This topic has 9 replies, 2 voices, and was last updated 8 years ago by
- September 12, 2018 at 3:38 pm #31507
fabeluna
I have a custom menu added to the content of the my-account woocommerce page. If I load the new my-accoount inquiry endpoint, all the menu titles of my custom menu are changed to “Inquiries” (See screenshot). I had a look at your code and I think it’s up to the “the_title” hook, located in the file “class-wcfm-enquiry.php” at line 53 and 282. It would be grateful if you could fix this in next update?
LeniAttachments:
You must be logged in to view attached files. - September 12, 2018 at 3:48 pm #31510
That’s something impossible, please check this – https://wclovers.com/wp-content/uploads/2017/11/wcfm_enquiry_myaccount.png
My Account from my system.You may even check at our demo as well – http://wcfmmp.wcfmdemos.com/my-account/
Can you please disable your custom code once and check this?
May you have missed something and that creates the mess.Thank You
- September 12, 2018 at 5:25 pm #31516
fabeluna
thanks for quick reply, great support!
The problem is only visible, if there is any other content element on the woocommerce my-account page, that uses the wordpress function the_title().. When I remove my custom menu from the my account page, everything works fine. I don’t know if it is not allowed or recommended to use another content element besides the woocommerce my account shortcode at the my account page?
Leni - September 13, 2018 at 7:52 am #31557
You are welcome π
When I remove my custom menu from the my account page, everything works fine. I donβt know if it is not allowed or recommended to use another content” – you may off course use that but your code should be like this –
$is_endpoint = isset( $wp_query->query_vars['inquiry'] ); if ( $is_endpoint && ! is_admin() && is_main_query() && in_the_loop() && is_account_page() ) { // New page title. $title = __( 'Inquiries', 'wc-frontend-manager' ); }“$is_endpoint” checking is very important here.
- September 13, 2018 at 8:50 am #31566
fabeluna
thanks for the code.
I Think you have misunderstood or I may not have expressed myself very well. See attached some screenshots for the purposes of illustration. On my Woocommerce account page I have placed the visual composer “dynamic_sidebar” element in addition to the “woocommerce_my_account” element. This sidebar contains the wordpress menu widget(WP_Nav_Menu_Widget) β I don’t use any other custom code by myself.
LeonieAttachments:
You must be logged in to view attached files. - September 14, 2018 at 4:11 am #31602
That’s really strange!
I have even show you the code using which we are setting menu title.Anyway, we will add some more restriction on this and hope you will not have this issue anymore.
- September 14, 2018 at 7:24 am #31621
fabeluna
Perfect, many thanks for this! π
Leni - September 15, 2018 at 11:49 pm #31728
WCFM new version is there, please update yours and take a look.
- September 16, 2018 at 8:58 am #31731
- September 16, 2018 at 4:45 pm #31751
MemberYou are welcome π
If you get a chance then please leave for me – https://wordpress.org/support/plugin/wc-frontend-manager/reviews/
- The topic ‘Inquiry menu title hook’ is closed to new replies.
