Diwali
05Day 03Hr 21Min 57Sec
Diwali
Integrate Buddypress Screens into WCFM Dashboard
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Integrate Buddypress Screens into WCFM Dashboard
Viewing 7 reply threads
    • #44104
      Dietcheese
      I would like to display my Buddypress dashboard pages (messages, friends, etc) *inside* your WCFM dashboard. That is, I *don’t want to display them above the WCFM dashboard*, but I want to show them as menu items on your WCFM, (ARTICLES, PRODUCTS, MESSAGES, FRIENDS).
      Is this possible? How would I go about it?
    • #44135
      Do you want to just add those as menu options under WCFM dashboard or want to show those content under WCFM dashboard as well?
      • #44159
        Dietcheese
        I want to show the BuddyPress content within the dashboard as well.
        I am comfortable with PHP but have not had much luck using endpoints and I’m not sure how to get the BuddyPress forms into your dashboard.
    • #44170
      Dietcheese
      Hello. Anything on this?
    • #44193
      Please get help form this custom addon – https://drive.google.com/file/d/1FHPiyEYCi78qapaYHSIcmHq3ilordR6G/view?usp=sharing
      This will help you to create custom menu and endpoint under WCFM Dashboard.
      But, how to show BuddyPress content that’s needs to be explore! Just find first, whether it has short codes for those pages?
    • #44255
      Dietcheese
      Yes, I have already used your custom addon and I’m able to create the new pages.
      The difficulty is incorporating BuddyPress. I’ve been trying to figure it out for many hours. There are no shortcodes for the forms.
      If you have any ideas please let me know.
      Thanks for your time!
    • #44312
      OK, we have to check this as well.
      I will know you.
    • #44501
      Dietcheese
      Thank you. I realize this is outside your plugin, but I really appreciate any direction you can give me.
    • #44543
      Sure, but we have to check BuddyPress options for this.
      I will know you.
  • The topic ‘Integrate Buddypress Screens into WCFM Dashboard’ is closed to new replies.
