Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Groups & Staffs › Invalid instance id
- This topic has 11 replies, 3 voices, and was last updated 6 years, 1 month ago by
georgina.
- April 22, 2020 at 10:15 am #121628
HM
ParticipantHello
I don’t know why but when I copy the api key and email
I have a problem of activation and it is said “invalid instance id”
Can you fix that please ?
I have the same problem with ultimate
In waiting for your response.
Good to you, - April 22, 2020 at 10:20 am #121629
Please deactivate and then activate license key.
- April 22, 2020 at 10:24 am #121630
HM
I have done that but it still doesn’t work - April 22, 2020 at 3:19 pm #121739
KeymasterAre you using the same email, you use as your user email in our website? If this doesn’t resolve the issue, then I will require a temporary backend access of your site. When sharing the access, please don’t forget to mark the reply as private.
Thank You! - April 22, 2020 at 5:45 pm #121801
HM
ParticipantThis reply has been marked as private. - April 22, 2020 at 8:44 pm #121900
HM
ParticipantThis reply has been marked as private. - April 22, 2020 at 9:05 pm #121905
KeymasterThis reply has been marked as private. - April 25, 2020 at 10:10 am #122797
HM
ParticipantThis reply has been marked as private. - April 25, 2020 at 11:19 am #122810
Its fixed now. Please check.
Thank You! - April 28, 2020 at 10:54 am #124044
georgina
ParticipantHow was this fixed?…I’m having the same problem
- April 28, 2020 at 11:01 am #124047
georgina
ParticipantGot it. Deactivate THE PLUGIN and activate it again. It worked then.
- The topic ‘Invalid instance id’ is closed to new replies.
