Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › invoices to follow european standard
- This topic has 9 replies, 3 voices, and was last updated 6 years, 7 months ago by
SebastianFloKa.
- February 8, 2020 at 3:21 am #106155
SebastianFloKa
ParticipantWould be great if all invoices followed European standard or could be adjusted in that way. So far I didn’t find somebody feasible to customize the templates accordingly. Main issues:
A) Membership invoice + B) Commission invoice: No invoice number displayed.
Any chance to implement this? Even the support-team of “wc pdf invoices & packaging slip” was not able to solve this. I case this is complicated: Would it help if the admin creates an separate vendor account in order to use the existing “wcfm store invoice number-feature” (where invoice-number works) for membership- and commission invoices as well?C) Store invoice: There’s only one VAT displayed instead of separate VAT-values.
Is there any possibility to split different VAT values (like VAT 20% = x; VAT 10% = y)? If it helps, it would be acceptable to name the corresponding VAT’s in WooCommerce backend accordingly (everybody as he likes), so it “just” requires to display this field and calculate the sum of each. - February 8, 2020 at 3:24 am #106156
SebastianFloKa
ParticipantConcerning point C) store invoice –> see attached picture for explanation.
You must be logged in to view attached files. - February 10, 2020 at 3:33 pm #106452
MemberKindly contact us here – https://wclovers.com/setup-guidance/
We will hep you to setup this.
- February 12, 2020 at 8:59 pm #106861
SebastianFloKa
Participant… Thanks for your reply – already contacted you via “setup-guidance” as requested.
Actually we are already in constant contact (via “WCFM customization”) concerning this topic since beginning of december. Unfortunately without prrogress. Don’t take it wrong – I fully understand that you are very busy and there are more urgent topics than this – but it’s a roadblocker.
As one doesn’t want to stop just before the finish line: In case anybody out there is running WCFM with EU legally correct invoices (VAT tax split on store-invoice / sequential invoice numbers on commission and membership invoice), maybe he can post a hint here how to achieve this. - February 14, 2020 at 1:49 am #107081
EDOUARDHOP
ParticipantHi, same here, i already posted a request on the custom invoice feature, like i do with WooCommerce PDF Invoices & Packing Slips Professional in another store, simple. not as the answer i got from WCFM,
i’m questionning Dokan at the moment, looks like they are enough interested to the EU market to add that feature - February 19, 2020 at 2:03 pm #107783
Do you have setup Tax Rules from WooCommerce tax setting? https://docs.woocommerce.com/document/setting-up-taxes-in-woocommerce/
If so, then those will by default visible under all invoices.
- February 19, 2020 at 3:37 pm #107845
SebastianFloKa
Participantthanks,
yes, attached my settings. If screenshot of all rates is required, please inform.
If you mean with “those” the different VAT taxes of topic C: Unfortunately not. See outcome of test-order with latest WCFM-template in attached picture.Topic A) + B): Any idea how to implement the sequential invoice number on the commission and membership invoice?
You must be logged in to view attached files. - February 25, 2020 at 2:33 pm #108705
Member - February 25, 2020 at 4:35 pm #108713
SebastianFloKa
Participant… answered you also per email but probably interesting for others as well: YES, this would be a big step. I can then readjust most of the lines. Only the sum of the different VAT’s will be difficult to handle for me, I think.
Also not to forget the invoice number on commission and membership invoice…
You must be logged in to view attached files. - April 12, 2020 at 2:50 pm #118400
SebastianFloKa
ParticipantAny chance to get the tax breakup as in your proposal?
- The topic ‘invoices to follow european standard’ is closed to new replies.
