Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Issue with a commission value
- This topic has 4 replies, 2 voices, and was last updated 6 years, 4 months ago by WCFM Forum.
- August 15, 2018 at 5:41 pm #28631KrisGuest
Thank you very much for this addon!
However, here is my first issue with it. I’d like to choose the commission type of % + fixed. But I can not set a fix amount under 1$. This is an issue. I’d definitely like the fixed amount to be less than a whole dollar. - August 15, 2018 at 7:42 pm #28633KrisGuest
Some more issues.
1. WCFM Ultimate Subscribe Button Label* does not seem to work. The text does not change.
2. I am able to put decimal fixed commission from single vendor settings page, but not on global settings as I already said. Also, there is no such setting at all for group. For group I only see % commission as in old version.
3. Made a new vendor on the test site. The new vendor appears in vendors tab and has a vendor user level in back-end, but in group settings i can not see that new vendor and can not add this new vendor manually to any group.
Note. I use WCFM Ultimate, Membership, Groups & Staffs on top of this new marketplace.Also using a ReHub WCFM theme and WCFM child theme, which seems to work almost fine with the new marketplace. Only the /vendors and /vendor/shop pages seem to be broken. But that is likely fixable.
- August 15, 2018 at 8:36 pm #28635KrisGuest
Correction. I use Rehub WCMP child theme.
From the d-n-13 bugs topic it’s probably safe to say that my issue with vendor role is connected to hes/her. issue. There are two user roles named “vendor”. - August 15, 2018 at 8:44 pm #28636KrisGuest
Here is a picture for the membership commission types missing:
https://imgur.com/a/KVmey5l - August 19, 2018 at 6:22 am #28876WCFM ForumMember
Thanks for get in touch with us and really appreciate your detailed descriptions.
1. WCFM Ultimate Subscribe Button Label* does not seem to work. The text does not change. – Hope you are talking about Membership plan page here, please correct me if I am wrong!
– You are right, we will add other commission types support in WCFM Membership next update.3. Made a new vendor on the test site. The new vendor appears in vendors tab and has a vendor user level in back-end, but in group settings i can not see that new vendor and can not add this new vendor manually to any group.
– This is already resolved in WCFm – Groups latest update (3.0.1)4. Also using a ReHub WCFM theme and WCFM child theme, which seems to work almost fine with the new marketplace. Only the /vendors and /vendor/shop pages seem to be broken. But that is likely fixable.
– Can you please send me a store page URL from your site to check how it’s look like?Thank You
- The topic ‘Issue with a commission value’ is closed to new replies.
