Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Issue with Google Maps API after upgrade
- This topic has 9 replies, 3 voices, and was last updated 6 years, 1 month ago by
- July 25, 2019 at 4:02 pm #73931
CommunityCorals
after upgrade to latest release I got attached message from the google maps API. The geo search is not working anymore.
https://stackoverflow.com/questions/34063439/invalidvalueerror-not-an-instance-of-htmlinputelement
https://stackoverflow.com/questions/35283887/what-does-this-mean-google-maps-apiLooks like an autocomplete error. Also maybe it would make sense to load the google maps script just on pages with a script. On my site its causing delays in speed.
You must be logged in to view attached files. - July 29, 2019 at 12:11 pm #74357
Well, this is because of API key.
Please talk to Google support for this.
Please do not follow those threads, very old. Google Map API now totally changed!
- July 29, 2019 at 12:13 pm #74358
CommunityCorals
ParticipantYes, thanks I am working on this. Which API is required for geolocation search? Is it the geolocation API or is the standard free java API good enough?
Thanks & BR
Dominique - August 3, 2019 at 5:03 am #74913
MemberFree Java API is good enough. But do not apply any restriction when you are creating API.
- August 3, 2019 at 6:59 am #74956
CommunityCorals
ParticipantAre you sure? I just once again created a fresh Javascript API key without restrictions. But when I go to filter store listing I get attached message.
DominiqueAttachments:
You must be logged in to view attached files. - August 4, 2019 at 9:12 am #75151
MemberYeah, we have created such API for many of our users.
Can you please talk to Google support once for this!
- August 23, 2019 at 8:01 pm #78059
Mitchell Gould
ParticipantI’m having the same problem. Did you ever solve it?
You must be logged in to view attached files. - August 28, 2019 at 5:18 pm #78805
MemberWell, it’s due to your Google Map API key, we have nothing to fix for this.
I have already told you to contact Google support, they will correct your API key for your site.
- August 28, 2019 at 6:09 pm #78812
Mitchell Gould
ParticipantActually, in my case, I found out that the error comes from the URL for my dev server not being on a URL I own. This works fine on my domain.
- August 30, 2019 at 7:23 am #79164
MemberOK, that’s very obvious.
Google Map API key works for specific domains only.
If I create a key for wclovers.com then it will not work for you domain.
