Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Issue with notifications by email
- This topic has 10 replies, 2 voices, and was last updated 6 years, 6 months ago by
- January 11, 2019 at 2:55 pm #43156
Jose
Since a few days ago I’ve been seeing something not complete in the notifications.
When for example I send a direct message to a vendor, he appears in the notices, but even when he should receive an email, he does not receive it.I have active all in notifications.
Regards
You must be logged in to view attached files. - January 12, 2019 at 6:19 am #43196
Please keep install this plugin – https://wordpress.org/plugins/wp-mail-logging/
And be sure, emails are triggered or not?
Direct message email triggered to vendor – https://ibb.co/zJqrQDb
- January 12, 2019 at 1:36 pm #43216
Jose
ParticipantThis reply has been marked as private. - January 14, 2019 at 4:56 pm #43517
Jose
ParticipantAny Idea ?
Regards,
- January 15, 2019 at 5:23 am #43562
Direct message from Admin to Vendor (see attach 1)
– Do you have send this message to all vendors or to that particular vendor only?
If you send this to “All” then there is no email notification. It’s because of, to reduce site load. Suppose you have 500 vendors the certainly system will send out 500 emails at a time, hugh pressure on server. Even, your emails address may be mark as “Spam”About ticket support I found a issue ? If I have hide to show email customer to vendor, why the email that receive vendor can replay direct to customer ?
– Will, definetely take care of this in next update
- January 15, 2019 at 10:54 am #43665
Jose
I have only one vendor, so I sent a direct message only to him.
Thanks again,
- January 16, 2019 at 8:15 am #43835
It does not matter how many vendors you have.
If you sending direct message without selecting vendor then it considered as “All” direct message – https://ibb.co/qJ7WYKd
For such case no notification email triggered.Thank You
- January 16, 2019 at 10:44 am #43877
Jose
Ok, I selected a vendor first, then wrote and send.
Maybe work if we have more of one vendor, need minimum two vendors to work ?
Regards,
- January 16, 2019 at 6:54 pm #43988
Jose
ParticipantUpdate !
I found a posible origin of issue.
I have another install of WCFM in another domain with no update plugins.
Multivendor Marketplace 2.0.3
Frontend Manager 5.2.6
Multivendor Membership 2.2.5And work direct message notification.
I can’t know where exactly the origin of the issue, but I’m sure that with the las update the problem appeared.In my working domain I have the last plugins from you.
Regards,
You must be logged in to view attached files. - January 17, 2019 at 12:52 am #44029
Jose
ParticipantResolved !
Was my fault, I found a filter in functions of my theme.
add_filter( ‘wcfm_is_allow_notification_email’, ‘__return_false’ );
Don’t remember why, but are erase.
Sorry and regards,
- January 17, 2019 at 4:43 pm #44133
MemberIt’s OK, thanks for the update 🙂
- The topic ‘Issue with notifications by email’ is closed to new replies.
