Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Knowledge Base Limit??
- This topic has 3 replies, 2 voices, and was last updated 7 years, 2 months ago by
- July 9, 2019 at 3:20 pm #71710
a.angel1310
I’m trying to create a knowledge Base and I was wondering if there is a memory limit to how much content can be placed into 1 post? I have added some text and pictures and everything saved fine up until a certain point where it won’t let me press the submit button anymore. Once I click submit the screen gets stuck on loading and won’t let me save any new content.
Thank you for your help
- July 13, 2019 at 7:21 am #72248
Well, there is no limit from WCFM.
But I think you are getting this due to server PHP setting. max post size.
- July 17, 2019 at 2:39 pm #72848
a.angel1310
ParticipantI will check PHP max post size but so far no errors generated in the log
- July 18, 2019 at 12:20 pm #72950
MemberOK, in such case in does not generate any error. But unable to save data!
Between, do you have enhance POST MAX size?
- The topic ‘Knowledge Base Limit??’ is closed to new replies.
