Limit Child Categories
Viewing 3 reply threads
    • #77089
      SSC
      Hello. In the capability menu, do you have a solution to limit child categories instead of parent categories?
      Or a hook/filter that I can work with too add the subcategories to the list?
    • #77461
      Sorry, right now this is not supported.
    • #77512
      SSC
      Alright.
      I did manage to get something to work by making some changes to the terms array for ‘product_category_lists’.
      I do seem to be having a problem to get it to work in a child theme though. I copied the file to ‘wcfm>capability’ but it does not recognize it. I didn’t have any problems with any other files, seems to just not work for ‘wcfmu-view-capability’ file
    • #77794
      Well, capability template can not be override and modified.
      If you still modified this and add sub-categories there still that will not work for product manager.
  • The topic ‘Limit Child Categories’ is closed to new replies.
