Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Limiting Products to one category
- This topic has 8 replies, 3 voices, and was last updated 6 years, 3 months ago by
sdel_nevo.
- May 25, 2019 at 2:29 pm #63729
sdel_nevo
ParticipantHi Guys
I have set the product category limit to 1 for my membership capability as I only want vendors to add products to a single category.
This works really wellWhen a vendor selects a category the checkbox is ticked if they then select another category and try tick select it, they cant until the first one is unticked, this is how it works now
would it be possible to change this to
untick the previously selected category automatically when selecting another category?hope this makes sense
Steve
- May 27, 2019 at 4:46 am #63920
Craig
ParticipantI would suggest that the system not let you select past the limit at all and display a warning that “max categories selected. Please un-select other to make room for new ones”
otherwise you are going to get people selecting and selecting and not realizing they are overwriting (deleting) the previous selection especially if those previous selections are no longer visible because the list is long and can’t be viewed in the smaller window.
- May 27, 2019 at 7:27 am #63938
sdel_nevo
ParticipantHi Craig,
I’m not sure I understand.
I plan and indeed will inform vendors that they can only publish products into one category, it just makes the workflow simpler I think as it cuts down the amount of clicking required
Steve
- May 27, 2019 at 8:06 pm #64012
Craig
Participantwhat I mean is that instead of automatically removing the last picked category it might be better that the user needs to “un-check it” before they can recheck a new one.
If you have lots of categories this would be recommended because the vendor gets that last chance to confirm that they are making the right decision by “un-checking” their previous selection and then selecting a new one. - May 27, 2019 at 8:22 pm #64013
sdel_nevo
ParticipantHi Craig
Yeah I did think about that before I raised the forum post, but for our workflow it suits to be honest
We won’t have many categories and to me it’s more logical if you can only post into one category the last one you select is the one it will go in.
I’m fine with that, and we plan to fully document this for our vendors. To me at least I think it’s a better fit for my site
Steve
- May 28, 2019 at 7:07 pm #64154
Please go to WCFM Capability setting and set “Product Categories Limit” to 1 – https://ibb.co/ZTcFvmh
- May 28, 2019 at 7:10 pm #64157
sdel_nevo
ParticipantHi guys
I have set the limit to 1 already
My question is
Is it possible to deselect the first category if a vendor selects a second?
Steve
- May 29, 2019 at 7:18 pm #64857
– Will add this tweak in next update.
- May 29, 2019 at 7:42 pm #64866
sdel_nevo
ParticipantHi guys
That will be fab
Many thanks
Steve
