Diwali
00Day 06Hr 14Min 42Sec
Diwali
Login Failed!
Viewing 5 reply threads
    • #83419
      Cap Luis
      I am using realy simple ssl pro! I disabled the strict http option, because I think this would get in the way, I don’t know I don’t understand much of what I’m doing.
      I set everything up but my app login is barred “login flahou”
      Please could check my code! I am attaching!
    • #83420
      Cap Luis
    • #83426
      Thanks for reaching out to us. I think there must be some mis-configuration. We cannot tell the exact reason unless we check the API requests!
      Can you provide us the following details1. Site Url, Temporary admin access, Temporary vendor access?
      We will look into cause of the issue and fix it.
      Thank you.
    • #83427
      Cap Luis
    • #83428
      Thanks, but can you please provide the site URL so that we can do the login?
    • #83550
      Solved the issue via email. So, Closing the topic.
  • The topic ‘Login Failed!’ is closed to new replies.
