Map markers on main product page are not accurate
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Map markers on main product page are not accurate
Viewing 7 reply threads
    • #124570
      tgl
      When you are zoomed in to level 1 to 4 the marker is not correct:
      https://www.screencast.com/t/c1iNCZjMfqjk
      The further you zoom out the more out of whack they get:
      https://screencast-o-matic.com/watch/cYfUj3B6jQ
      Anyone else having this issue?
    • #131588
      Hi, I have this problem also since the last update of WCFM products.
    • #131989
      tgl
      @tupresenciaonline.com
      I just got an email back from support telling me that it has always been this way, it’s an issue with Google.
      You said you had it working previous to the recent update?
    • #132162
      Hi @tgl,
      That is not true.
      I will put the two cases of operation:
      WCFM – WooCommerce Frontend Manager – version 6.4.8 and WCFM – WooCommerce Multivendor Marketplace – version 3.3.8
      http://deb.andorramarketplace.com/tiendas/
      WCFM – WooCommerce Frontend Manager – version 6.5.0 and WCFM – WooCommerce Multivendor Marketplace – version 3.4.0
      https://andorramarketplace.com/comercios/
      If you observe, the behavior has changed between versions
      Before, the map pointers were shown in blue, without grouping, and their geo positioning was correct.
      Now with the latest version the map pointers have a different style (they have the color green), they are grouped and the geo position is not working well. Also with zoom this problem is even more serious.
      The truth is that to have a map that the geo position does not work. It is better not to use it, because my users are getting angry.
      I hope that the WCFM team can give us a solution to this problem.
      Regards.
    • #133970
      Hi, do you know anything about this problem?
    • #133996
      paul-8288
      Brian cant seem to reply/login to this forum to reply to you, but said you can contact him over on the unnoficial FB page here
      https://www.facebook.com/groups/users.of.wcfm.marketplace/?fref=nf
      Paul
    • #134002
      Applied for request to belong to the FB group.
      Thanks Paul.
    • #138522
      antoinenavarro59
      I have exactly the same problem, it is a disaster on the visual of the map! Is it possible to revert to the previous version without losing the modifications and the work done?
  • The topic ‘Map markers on main product page are not accurate’ is closed to new replies.
