Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Membership Cancellation
- This topic has 13 replies, 2 voices, and was last updated 7 years ago by
- May 14, 2018 at 5:26 pm #23277
dale
ParticipantI have created a membership called Non-member for cancelled memberships. The Non-member membership is assigned to the group non-member. The capabilities of this group are set to off for adding products, managing products, publishing products.
Therefore on cancellation the member should not be able to add products however this doesn’t seem to be working and the member who has cancelled is still able to add products.
Why isn’t it working?
- May 14, 2018 at 8:30 pm #23311
I got your concept. But how are cancelling membership?
In WCfM – membership only cancel option comes for subscription memberships, for cancelling subscription.
Are you trying this?Thank You
- May 16, 2018 at 1:19 pm #23392
dale
ParticipantNot sure what was happening but it seems to be Ok now.
When the vendor has cancelled their subscription is there a way to remove them from the frontend of the website? Their details are still showing along with any products they’ve added.
- May 16, 2018 at 3:09 pm #23405
– What kind of details you are referring here? Can you please show me some screenshot for this?
- May 16, 2018 at 6:23 pm #23425
dale
ParticipantThis member cancelled the subscription and became a “non member” which is the membership assigned when they cancel. As you can see the details of the vendor and products are still on the website.
- May 16, 2018 at 7:33 pm #23435
Ok, now I understand the point you are having.
Actually , cancel membership is not like that. It’s for, when a vendor cancel his subscription then this plan will assign to them.
It’s like a FREE or very low end plan with minimal features.
- May 17, 2018 at 10:03 am #23466
dale
ParticipantOK, so how can their details be removed from the frontend? Does this have to be done manually?
- May 17, 2018 at 11:10 am #23467
MemberWell, this only possible by changing that user role to something else than “Vendor”.
Then, this user will not allowed to access front-end dashboard as well.
This can be set automatic as well.
- May 17, 2018 at 12:17 pm #23471
dale
ParticipantOk, so then how do I make it automatic?
- May 22, 2018 at 4:42 pm #23682
dale
ParticipantCan you answer my last question? Tks
- May 22, 2018 at 4:44 pm #23683
Sorry for the delayed response.
I will give a code snippet for this but right now plugin has no such filter to add this snippet from outside.
So I am for the next update as this code will work only after that.
Don’t worry, I have this in mind and will give you that code.
- May 22, 2018 at 6:29 pm #23692
dale
ParticipantOK, thank you
- May 28, 2018 at 8:23 pm #23926
WCfM 4.1.2 has just released and it allows you to disable any vendor account anytime.
- June 17, 2018 at 11:22 am #24990
WCfM – Membership 2.0.0 has just released.
It comes with many new features including “Cancellation Rules”.
Check video tutorials as well – https://wclovers.com/wcfm-tutorials/
- The topic ‘Membership Cancellation’ is closed to new replies.
