Membership subscribe shortcode
Viewing 9 reply threads
    • #23812
      Kristin
      I’m trying to use the membership subscribe shortcodes but can’t figure out how to make them work. If I just place the shortcode on a blank page, nothing shows up. Is there something that needs to be added along with the shortcode?
    • #23824
      Kristin
      Just to add… I’ve tried disabling all except the necessary plugins (everything except WCFM, WC Marketplace & Woocommerce) as well as switching themes to see if something might be conflicting, but it had no effect. Still a blank page.
    • #23831
      Are you trying to see that page when already logged in as Admin? Then you will blank page.
      As this button visible to non-logged in user or those user roles which are allowed to subscribe as vendor.
    • #23832
      Kristin
      Ah! That never even occurred to me… yes, I was trying as admin. It does appear when I try as a regular member. Thanks!
    • #23833
      Great 🙂
    • #23835
      Kristin
      One other question about the membership buttons – I figured out how to use css to change the text color but I can’t figure out how to align the button in the space. Can you tell me how to center it? Right now it’s aligned on the left side.
    • #23849
      Can you please show screenshot for this?
      Possibly something added CSS “float: left;” for that element.
    • #23856
      Kristin
      You can see a screenshot here: https://www.dropbox.com/s/72erqeg3b1ztr2j/Screen%20Shot%202018-05-26%20at%2011.47.25%20AM.png?dl=0
      The formatting via the text box is set to center, but the button stays on the left, no matter what I’ve tried.
    • #23858
      Thanks for the screenshot.
      Well, check this – http://wcvendors.wcfmdemos.com/vendor-membership/
      WCfM Membership by default style set this button in center.
      But here some of your theme CSS makes this revert to left.
      Now, it’s difficult for me to guess.
      Is your site in web, can you share your membership page with me to check this?
    • #23993
      Kristin
      Thanks but I’m good now… the developer of the pricing table plugin I’m using helped me get it working the way I want.
  • The topic ‘Membership subscribe shortcode’ is closed to new replies.
