Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Membership via PayPal issue
- This topic has 7 replies, 2 voices, and was last updated 7 years, 10 months ago by
- July 24, 2018 at 3:08 pm #26878
Kristin
GuestSomething isn’t working right with WooCommerce Subscriptions + WCFM + PayPal.
I’ve had this happen twice this morning … a vendor signs up for a membership via PayPal. The payment goes through successfully and the Woocommerce order shows as completed. The funds are in my PayPal account and the transaction there also shows as “completed.” The Subscription in the admin vendor dashboard shows as “Active” on the individual transaction page, but on the list of subscriptions, it shows a “pending” sign. When I look up the subscription on the “Subscriptions” list in Woocommerce, it shows as “pending” there as well. The vendor was switched to a “disable vendor” user role somewhere in the process and the “expired membership” email was triggered in WCFM.
- July 24, 2018 at 3:15 pm #26879
Kristin
GuestThis is from the Woocommerce error log for those two orders:
2018-07-24T05:56:36+00:00 ERROR Status transition of order #25926 errored!
2018-07-24T08:29:38+00:00 ERROR Status transition of order #25946 errored! - July 24, 2018 at 4:22 pm #26882
Kristin
GuestFYI… in further testing, the problem is not limited to PayPal. It also happens when using Stripe.
- July 25, 2018 at 6:54 pm #26918
Kristin
GuestAny thoughts on this? I can’t launch my site until I figure this out…
- July 26, 2018 at 3:22 pm #26963
I have tested this but unable to generate.
“ERROR Status transition of order #25926 errored!” – it’s not from WCfM.
Actually, when you are using WC Checkout then WCfM – Membership does nothing. Only when that Order marked completed it triggers.
Did you checked in your PayPal ? Is subscription/recurring profile properly created?
I only can assume, there has something due to that PayPal IPN not received or processed!
Between, why that user membership expired? How many days membership is this?
- July 26, 2018 at 3:58 pm #26971
Kristin
GuestTo answer your questions:
Actually, when you are using WC Checkout then WCfM – Membership does nothing. Only when that Order marked completed it triggers. >>> Orders are marked as complete in Woocommerce and it tries to trigger the subscription change but as the error log shows, it is not working.
Did you checked in your PayPal ? Is subscription/recurring profile properly created? >>> Yes – everything looks like it is working correctly in PayPal. The recurring payment is correctly set up, the appropriate emails sent, etc.
I only can assume, there has something due to that PayPal IPN not received or processed! >>> I discovered after my original post that this happens with Stripe also. It does not appear to be a payment processing issue.
Between, why that user membership expired? How many days membership is this? >>> The membership subscriptions weren’t supposed to expire – both are 6-month memberships. I’ve been testing the last couple days – it happens with every sign-up, not just PayPal and regardless of length of subscription.
- July 27, 2018 at 1:46 pm #27017
Kristin
GuestI finally figured out the problem – I had a snippet that was controlling some other Woocommerce-related functions that was interfering with the subscription activation process. All good now.
- July 28, 2018 at 11:06 am #27029
MemberAhh .. that’s great to know things are working perfectly for you 🙂
- The topic ‘Membership via PayPal issue’ is closed to new replies.
