Merge product for sigle product multi vendor
Viewing 1 reply thread
    • #114074
      advers1ty
      Good morning, everybody, I’m new and I moved from dokan to the wcfm.
      I wanted to ask two technical/functional things.
      1) Can i merge 2 equal products (same sku) but loaded at 2 different times by 2 sellers, to make it 1 product with more sellers? (they didn’t notice the product already present and didn’t use the clone function)
      2) if a csv is loaded by a seller, is it possible that by means of sku example, it is possible to automatically merge the products ? i.e.. I already have online the product with sku: “example-123” and a seller loads his csv with a product with the sku “example-123” in the list, can it merge automatically using the function one product and several sellers ?
      Thanks in advance for your answers
    • #114736
      Please contact us here for the purpose- https://wclovers.com/woocommerce-multivendor-customization/
  • The topic ‘Merge product for sigle product multi vendor’ is closed to new replies.
