Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Appointment › Missing Appointment Icon
- This topic has 5 replies, 5 voices, and was last updated 5 years, 7 months ago by
Justin McErlain.
- December 30, 2019 at 11:58 am #100004
- January 3, 2020 at 2:29 am #100649
carmen medina
ParticipantHello! I didn;t have the option of booking or appointment in my dashboard and I download the woocommerce booking. Who can help me with that problem. My business is all about appoinment on demand
- February 26, 2020 at 4:53 pm #108900
terrence.bunkley
I have the Appointments plugin but Staff and Appointment are not showing up under WCFM manager. Any suggestions? - May 26, 2020 at 8:15 am #135269
- May 28, 2020 at 2:45 pm #136146
Justin McErlain
ParticipantHi, Same problem here can we get a solution ?
- May 29, 2020 at 2:21 pm #136475
Justin McErlain
ParticipantHi, I fixed this by going into capability settings in Admin and turning all related settings on / off again. Also checking the FAQ which gives some indication see below. Hope this helps.
functionality you have to install the core plugin as.
For Booking-
1. WooCommerce Bookings (https://woocommerce.com/products/woocommerce-bookings/) in required.
If you already have installed WooCommerce Booking but still not visible –You are not getting Booking Menu on left Sidebar at WCfM Dashboard?
Even as Admin login !!
Can you please make sure one thing –
Booking plugin folder name should be same as you get it from WooCommerce.com
As admin I can see it, but as a Vendor I can not see it.
If as Admin you can see it then Folder name is right.
Your Vendors don’t have Booking Capability, it’s just the reason.
Just go to WCfM Capability, it’s under WCfM frontend Settings as Admin login.
Please be sure “Manage Bookings” is ON and just press Save.
There is another option under Product Types – Booking, it’s specially for allowing Bookable Product. Keep that also ON.
You are done, now login as Vendor and check.
