Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Bookings › Missing options when create a new product from creating a listing
Tagged: Accommodation product, Add-ons, booking, has persons
- This topic has 2 replies, 2 voices, and was last updated 6 years, 11 months ago by
- December 23, 2019 at 6:01 pm #98743
jl.lo
When I add a new listing and create the accomodation product that “has people” using the “Create new product” button https://ibb.co/8567vgJ i´m missing the options to configurate the persons. The options to select it´s appears, https://ibb.co/2FWj2Jt but there is not option configuration during the product creation process. Later, if I go to Products and edit, the option is there to can configurate the “has persons” options.
Also i´m missing the ADD-ONS option. In this case appears the step on the process, but empty https://ibb.co/XXkL51v
I hope you can fix thoses isues on the futures plugins update.
- December 27, 2019 at 4:21 pm #99507
jl.lo
ParticipantAfter creating that type of product, if you go to edit it again, the option “has person” does not appear and you have to re-check the box “has persons” so that the options appear and can be edited.
https://ibb.co/gj5C96f
https://ibb.co/mTnrzpB
https://ibb.co/m8McdZd
https://ibb.co/qm8V1K0I also have sent this issue through the “priority support”.
- December 28, 2019 at 11:21 am #99663
MemberWe will update you over priority email on this.
- The topic ‘Missing options when create a new product from creating a listing’ is closed to new replies.
