Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Multiple Provider Stores that will pay commissions and others that will not.
- This topic has 12 replies, 3 voices, and was last updated 6 years, 6 months ago by
- March 5, 2020 at 7:15 pm #110116
alexandermartineznm
ParticipantHi, I have a store with multiple suppliers, but there is a store that will pay commission and another will not.
What I want is that in the configuration of commissions by the administrator you choose which store will pay commissions and which not.
example
Store panel – CommissionsName Yes / No
Store 1 yes
store 2 no
store 3 no
store 4 yes - March 5, 2020 at 7:44 pm #110120
SebastianFloKa
Participant… Just use WCFM Groups&Staff and create one group with commission and one group without commission….
You can decide how the registration process look like so you can move your vendors manually to whichever group you like. - March 5, 2020 at 8:02 pm #110121
alexandermartineznm
ParticipantIt is not necessary to buy WCFM Ultimate and WCFM Groups & Staff to be able to do that. You can simply configure the WCFM MarquetPlace.
- March 5, 2020 at 8:15 pm #110122
SebastianFloKa
Participant… OK, it would have been better to write “I solve this with Groups&Staff” …
- March 5, 2020 at 8:18 pm #110123
alexandermartineznm
ParticipantYes, but remember that each provider can choose whether to pay fixed or per cent commissions, there must be an option where he says not to pay commissions
- March 5, 2020 at 8:24 pm #110124
alexandermartineznm
Participanthere is the option that I speak to you where the commission configuration appears there should be the option of not paying commissions
https://wclovers.com/wp-content/uploads/2018/08/wcfmmp_commission_mode-768×405.png - March 8, 2020 at 10:08 pm #110613
alexandermartineznm
ParticipantHello, one option that I can think of is to put the commissions in the category, so the store chooses if it will pay commissions. with the category.
Category 1, RD $ 50 fixed from commission to product <to RD $ 1,000
Category 2, RD $ 100 fixed from commission to product <to RD $ 19,999
Category 3, 0.005% commission on product> at RD $ 20,000
While the option I requested here is resolved so much
- March 10, 2020 at 6:02 pm #110948
- March 10, 2020 at 7:31 pm #110971
alexandermartineznm
Participantin that part of a supplier’s commissions, I don’t see the option to turn off commissions for that provider, that’s just the different way to set up commissions as shown in the image
https://wclovers.com/wp-content/uploads/2018/08/wcfmmp_commission_vendor_setting-600×223.png
if there is no such option I can choose the fixed commission and put 0
- March 10, 2020 at 8:05 pm #110973
alexandermartineznm
Participantfor when this update will be ready for the tool to convert the products to affiliate link this directly into the products as amazon does at the top (<head>)
- March 10, 2020 at 9:46 pm #110997
alexandermartineznm
Participantby the time this update will be ready
- March 10, 2020 at 9:55 pm #110999
alexandermartineznm
Participantsorry the last two message that is posted here does not correspond to this topic
- The topic ‘Multiple Provider Stores that will pay commissions and others that will not.’ is closed to new replies.
