Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Multiple store order status under same invoice causing confusion
- This topic has 2 replies, 3 voices, and was last updated 7 years ago by
- June 14, 2019 at 12:04 am #67522
richard.cannasolutions
ParticipantMy vendors are noticing an issue with order status. When customers place a multivendor order under one invoice, each vendor receives the order which has the same Invoice order number. The vendors begin to fulfill their respective orders but they have found out that when either changes the status of their respective orders it automatically changes the status of the other vendor as well. So, in other words, multivendor orders under the same invoice number affect other vendors order status as well.
I am confused but ask if theirs a solution for this?
Thank you for your assistance.
- June 14, 2019 at 8:19 am #67578
CommunityCorals
ParticipantYou need to set order status as “unsynced”. This way the order status you see in backend will stay untouched. Vendors than have their own order status they can use seperatly without influencing the other. In database this status is called “commission_status”
BR
Dominique - June 15, 2019 at 4:04 pm #67843
MemberDisable “Order Sync” option from WCFM Admin Setting -> Marketplace Setting – https://ibb.co/PMrMV04
- The topic ‘Multiple store order status under same invoice causing confusion’ is closed to new replies.
