Diwali
01Day 10Hr 11Min 15Sec
Diwali
Multiselect custom fields issue
Viewing 1 reply thread
    • #23925
      Tavy
      I have several select fields in ACF where I’m allowing multiple selections. They work for the most part in WCFM, but the only issue is that these are required fields, and they cannot be null. Currently if I open a product page in WCFM to test it, it shows the select field, but it autoselects “-Select-“. This is to say that a chip has been rendered for the phrase “-Select-” as if I had already selected it. And it lets me click submit without saying that the field is currently empty. For some reason it considers “-Select-” as a valid option. How can I get it to not add that -Select- chip?
      Does anyone else have the same issue with multiselects in WCFM?
      Thanks for your help!
    • #23932
      Thanks foe get in touch with us.
      You are right, this issue was there.
      WCfM 4.1.2 has just released and this has been already resolved.
  • The topic ‘Multiselect custom fields issue’ is closed to new replies.
