Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › ORDER SYNC
- This topic has 5 replies, 2 voices, and was last updated 7 years, 11 months ago by
Dan.
- December 1, 2018 at 6:00 am #38769
Dan
Can I check with you on the following scenario in a single cart:
1. Customer A bought product B listed by vendor B
2. Customer A also bought product C listed by vendor C
3. Vendor B marked status as completed for product shipped out.
4. Vendor C is still on hold for the status.
5. When Vendor B marked order as completed, the order status is marked as completed. Shouldn’t this be partial as payment is fully captured at payment gateway (stripe)?
How do I rectify this ?
- December 3, 2018 at 6:35 am #38845
Please keep disable “Order Sync” option – https://ibb.co/t8h94vZ
Hence, each vendors order status will be handled separately and main order status will not affected by any vendor’s order status update.
- December 5, 2018 at 10:04 am #39075
Dan
Thanks for the response.
If that’s the case, how do I know when different vendors under the main order has processed/ completed their sub order at the order management page under admin account ?
Is there any way I can view them and not clicked in each main order itself ??
- December 6, 2018 at 8:28 am #39142
– You will receive notification for all these as Admin.
WCFM Notification and WC main order note both will be updated.Thank You
- December 6, 2018 at 8:29 am #39143
- December 9, 2018 at 1:39 pm #39426
Dan
Noted w thanks.
Rdgs
Dan
- The topic ‘ORDER SYNC’ is closed to new replies.
