Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Payment Method Limitation
- This topic has 12 replies, 3 voices, and was last updated 7 years, 3 months ago by
- December 18, 2017 at 11:17 pm #17027
gilservant
ParticipantGreat Addon however since this is working with woocommerce I would suppose it was to use the power of woocommerce global payment gateways as opposed to being limited to paypal which brings too much limitations to countries not supported by paypal…. There is woocommerce subscription plugins which can be used to run subscription
Please guys consider this other most of us are excluded by default
- December 19, 2017 at 10:15 am #17037
Thanks for get in touch with us and your suggestions.
We understand this limitation and going to add Bank Transfer support in next update.
Also there will be a option so that you may associate a WooCommerce Subscription product with this for checkout.
Frankly, we didn’t want to make this dependent on WooCommerce Subscription, then a free plugin will only works if you have WC Subscription ($199) that will be a much bigger limitation.
- December 22, 2017 at 5:27 am #17108
MC
GuestThat would be an excelent idea. Also, why the normal dokan and woocommece register page is not used? It is a problem because my register page is also sychronised whith buddypress.
What would be amazing is to have a shortcode for plans and on the register page a checkbox to choose the vendor plan you want before registering.Thanks
- December 23, 2017 at 5:43 am #17130
WCFM – Membership new version has just released and it comes with “Bank Transfer” support.
Kindly update yours and take a look, please know me is this helpful for you or not!
Just to mention, we are going to add custom fields option in registration form in next version, if you go with default registration form then it will breaks the flow and restricted us in many ways.
Hope you understand, please know us if you have any other suggestions.
- December 28, 2017 at 6:13 am #17287
Marialaporca
GuestGreat! Personnaly I use stripe and wp affiliate so it wont work if it is not using woocommerce. Is it possible for us to put a shortcode in order to put the plans everywhere we want in the site? And will it be integrated to buddypress specific fields in the registration page. Thanks
- December 31, 2017 at 6:40 am #17389
You can add “[wcfm_vendor_membership]” shortcode anywhere show membership plans.
WCfM – Membership will have Stripe support very soon.
But I am not clear enough how “wp affiliate” will be integrated with Membership plans?
- January 4, 2018 at 9:58 am #17545
Yogendra Gupta
I want CCAVENUE paymnet gateway which i am not able to. Please Help in that. As our clients dont prefer PAYPAL gateway.
- January 4, 2018 at 10:05 am #17547
Thanks for the suggestion. We are looking into this and trying to integrate this ASAP.
Thanks Again.
- January 4, 2018 at 10:12 am #17548
gilservant
ParticipantI saw a plugin which was using a woocommerce for checkout…. Can you not hook woocommerce to be used to checkout the membership?
- January 7, 2018 at 6:33 am #17614
We don’t want to add this dependency because then for creating subscription based membership users have to purchase WooCommerce Subscription ($199) which will be a big hectic for them.
- January 8, 2018 at 11:44 am #17627
gilservant
ParticipantMy suggestion was not to use woocommerce Subscription but to use woocommerce as a payment method. I use these plugins and the use woocommerce for payment but not relying on woocommerce subscription.
https://codecanyon.net/item/web-20-directory-plugin-for-wordpress/6463373
https://codecanyon.net/item/cardojo-the-most-advanced-cardealer-marketplace-wordpress-plugin/20613160 - January 15, 2018 at 7:20 pm #17972
MemberThanks for the suggestions, we will look into these.
Regards
Simha - May 12, 2018 at 3:44 pm #23193
Kindly follow this – https://wclovers.com/forums/topic/wcfm-membership-using-wc-products/Thank You
- The topic ‘Payment Method Limitation’ is closed to new replies.
