Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › PDF Voucher Variable product not working.
- This topic has 13 replies, 2 voices, and was last updated 6 years, 4 months ago by
- April 15, 2019 at 5:36 pm #57934
d-n-13
ParticipantHello wclovers,
PDF Voucher works perfect with single product, but variable product not working at all.
1- It will not send the voucher code : https://www.dropbox.com/s/1men8j84gfwoxbt/Voucher%20PDF%20issue.jpg?dl=0
2- It will ask you to add weight and dimensions even tho the variable product is set virtual : https://www.dropbox.com/s/0lg5w23sw7uxoqh/Voucher%20PDF%20issue%202.jpg?dl=0
3- Some side menus should not be visible while doing same options inside product variations : https://www.dropbox.com/s/hfk1h6oayvpvfhn/Voucher%20PDF%20issue%203.jpg?dl=0
- April 18, 2019 at 5:11 pm #58469
Please create a product from wp-admin -> Products -> WooCommerce default product manager
We have followed same login as there!
- April 18, 2019 at 5:17 pm #58470
d-n-13
You want me to create product in wp-admin for testing ? or a solution ?
My vendors want to create in frontend.
- April 18, 2019 at 5:25 pm #58472
– Just test once.
- April 18, 2019 at 5:42 pm #58486
d-n-13
ParticipantOkay
- April 19, 2019 at 3:08 pm #58632
d-n-13
ParticipantHello, I’ve done testing on wp-admin creating products
1- Voucher PDF products translates with no issues.
2- Voucher PDF Variable products translates with no issues.
3- (unrelated bug) Translated products from wp-admin has no vendor and has no way to assign vendors.
4- (Important Voucher PDF feature missing) in wcfm vendor cannot see purchased codes unlike in wp-admin edit product page who has that option. Screenshot : https://www.dropbox.com/s/c1e4klsh8iyi23g/Annotation%202019-04-19%20180730.png?dl=0
- April 21, 2019 at 5:15 am #58785
Please update WCFM U 6.0.3 and take a look.
– Well, if you are editing using “WooCommerce Multilingual” edit screen then not possible. But if you edit using WC edit product screen, then you may do this.
- April 21, 2019 at 7:00 am #58810
d-n-13
after update still cannot translate single product with PDF Voucher correctly, it moves main language product to 2nd language… screenshot attached.
and for variable product, it’s not working at all, not generating stock quantity numbers and not sending codes to customers.
You must be logged in to view attached files. - April 21, 2019 at 7:01 am #58814
d-n-13
Participantwcfm ultimate wasn’t updated, will update it and test again then come back to you
- April 21, 2019 at 7:07 am #58815
MemberPlease, Ultimate update essential for this.
- April 21, 2019 at 10:18 pm #58895
d-n-13
1- stocks doesn’t auto generate when using variables.
2- after update I cannot add product to cart. Before the update i was able to add it to cart but it won’t send code, it sends empty pdf
3- When using variable products, main inventory menu and main dimensions menu should be hidden, because I have stock and dimensions Required vendors cannot do variable products before adding stock and dimensions. Screenshot attached.
You must be logged in to view attached files. - April 25, 2019 at 5:32 am #59285
– WooCommerce does not have any functionality.
– Hope you have already test from wp-admin -> product manager – WooCommerce does not do that!
Concept is, you have to set global stock, dimension etc .. and those will be applicable on each variations. But it’s also possible to override those at variation label.
- April 25, 2019 at 9:17 pm #59463
d-n-13
ParticipantLooks like there is no easy solution for this, I will let it go.
Thanks for your help
- April 29, 2019 at 6:04 am #59814
MemberRight, no alternate fro this right now.
- The topic ‘PDF Voucher Variable product not working.’ is closed to new replies.
