wcfm-santa
Wishing you joy this Diwali and Halloween! Enjoy up to 20% off on all addons!
00Day 00Hr -52Min -59Sec
wcfm-santa
pending vendors
Viewing 5 reply threads
    • #138021
      MarsMars
      hello,
      I have added custom data to the vendor registration form. from the settings
      I want to show theses data in the screen for pending vendor approval. how cab I do that view file should I change or what hook should I use to this
      regards,
    • #138248
      In “Vendor Application” is already display the “custom registration fields”.(PFA)
    • #138292
      MarsMars
      yes it appears in the application form and vendors are filling it
      I want to see this data on the second screen you attached
    • #138403
      Sorry, unfortunately, we don’t have filter/hook in this message dashboard to add custom data.
    • #138505
      MarsMars
      is there a view I can modify this .. this is causing problem for me . I need to verify them before approval
    • #140625
      MarsMars
      thanks .. I did not notice that
