Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › per row shortcode is not working
- This topic has 3 replies, 2 voices, and was last updated 5 years, 4 months ago by
Sarmistha Chakraborty.
- May 7, 2020 at 2:02 am #127718
freelancerfathe
I used this short code [wcfm_stores per_row=”4″ per_page=”20″] but its not working. Its showing 3 stores per row. check this out https://test.voila24.ch/all-stores/?v=981ddb581570 . I created 4th number store then the new store is showing under 3rd number store then I deleted the new one. can you please help me to solve this problem.Thanks
You must be logged in to view attached files. - May 7, 2020 at 1:01 pm #127907
It seems like the shortcode is written wrongly.
Please modify the shortcode –
[wcfm_stores per_row=4 per_page=20]
- May 9, 2020 at 2:47 am #128609
freelancerfathe
ParticipantHI,
Thanks for your help.can you please tell me how can I do this Local pick up needs to be: local
Delivery which will be allocated through specific postcode areas permitted.Thanks
- May 9, 2020 at 1:37 pm #128779
You can use “Zone wise” shipping for this.
https://docs.wclovers.com/zone-wise-admin-settings/
https://docs.wclovers.com/zone-wise-vendor-settings/the “[wcfm_stores]” shortcode is working now?
Please for different issue create different thread.Thanks.
