WCFM Anniversary
We've turned 8! Celebrate with us and take away upto 25% OFF on WCFM Addons.
02Day 20Hr 47Min 56Sec
WCFM Anniversary
PLEASE HELP – Vendor Registration form is corrupt!!
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Vendors PLEASE HELP – Vendor Registration form is corrupt!!
Viewing 4 reply threads
    • #75768
      Peter McCarthy
      I posted under membership several days ago without any answer – Please help – you say you want to help people as much as possible but you do not answer the forum. Vendor registration form is not displaying correctly please see the attached file. Is there a fix for this display problem.. Thank you.
    • #75959
      Peter McCarthy
    • #75965
      Peter McCarthy
      I also have this same question on the forum which you answered as below but the forum will not allow me to log in to give you the url so I put it here (above). Please note that tyour website log-in has a problem with capture – It will not allow me to fill in my details and capture together! When I do one and then try the other it tells me I have not entered correctly.
      [WC Lovers] Vendor Registration Form – ProblemWCfM Forum wrote:
      I think this is due to theme CSS.
      Can you please share this URL with me? I will know you fix CSS for this.
      Post Link: https://wclovers.com/forums/topic/vendor-registration-form-problem/#post-75950
      You are receiving this email because you subscribed to a forum topic.
      Login and visit the topic to unsubscribe from these emails.
    • #76149
      Peter McCarthy
      Hello.. Thank you for all your help. After days of trying to fix this I deactivated all plug-ins, then reactivated them and everything is okay now!
      The problem is solved 🙂
    • #76194
      Great … thanks for the update 🙂
      Possibly it was due to caching!
  • The topic ‘PLEASE HELP – Vendor Registration form is corrupt!!’ is closed to new replies.
