Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Plugin conflict with Rank Math SEO
- This topic has 10 replies, 3 voices, and was last updated 5 years, 4 months ago by
SebastianFloKa.
- April 22, 2020 at 7:49 pm #121887
- April 23, 2020 at 5:22 pm #122182
Right now, WCFM is not fully compatible with Rank Math SEO. We could add that compatibility, if got more requests. Alternatively, you could use Yoast for now.
Thanks! - April 23, 2020 at 5:54 pm #122205
alexdezi
ParticipantAlright, thank you!
Maybe you want to consider Rank Math SEO 🙂
They are trying to get this fixed.
- April 24, 2020 at 11:15 am #122408
KeymasterI tested in my local setup but couldn’t get any error like this. This may be due to some other problem. Please check at wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log -> is any error generated?
Let me know.
Thank you! - April 24, 2020 at 6:46 pm #122556
alexdezi
ParticipantHello and thank you!
Yes, this is the error log I get:
2020-04-22T00:46:42+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/public_html/dai-dai.it/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
- April 24, 2020 at 7:15 pm #122571
KeymasterPlease send the whole error log of 22/04/20. Though I have again checked with a new installation and could not be able to replicate the issue (all plugins latest version). Can you just try deactivating your other plugins apart from WooCommerce, WCFM plugins, and Rank Math, to know the cause.
Let me know. - April 25, 2020 at 12:32 am #122693
alexdezi
ParticipantI have checked now with all the plugins, but it’s only not working with Rank Math SEO.
I tested it on a staging environment, still the same problem, I don’t get it to work. If you would like to check it out I can give you access to it.
This is the Log of today:
2020-04-24T18:52:54+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
2020-04-24T18:53:31+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
2020-04-24T18:53:50+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
2020-04-24T18:54:14+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
2020-04-24T18:54:39+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
2020-04-24T18:55:18+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
2020-04-24T18:55:42+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
2020-04-24T18:56:09+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
2020-04-24T18:57:06+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
2020-04-24T18:57:48+00:00 CRITICAL Object of class WP_Error could not be converted to string in /home/travelg3/staging/1/wp-content/plugins/wc-frontend-manager/controllers/products/wcfm-controller-products.php in Zeile 312
- April 25, 2020 at 11:24 am #122811
Are you using the latest version of both the plugins? You mentioned, you contacted Rank Math guys. What they are saying about this?
Let me know!
Thanks! - April 25, 2020 at 6:11 pm #122925
alexdezi
Participantyes, everything is updated.
I gave them access to the staging site, they will check it out: https://support.rankmath.com/ticket/plugin-conflict-with-wcfm/#post-46670
- April 26, 2020 at 10:43 am #123153
KeymasterOkay, please keep us posted on this.
Thank You!
- April 28, 2020 at 3:59 am #123965
SebastianFloKa
ParticipantI’m not facing above issue but want to mention that RankMath compatibility would be great.
I saw a post some time ago saying like “you can use RankMath” but now I learned that vendor SEO is not yet supported. So I will switch probably to yoast SEO for the moment.
