Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Pre-registered Products
- This topic has 13 replies, 2 voices, and was last updated 7 years, 9 months ago by
- January 8, 2019 at 2:53 pm #42692
Rafael
GuestI want to know if WC Lovers has any module or feature where the market owner leaves pre-registered products for new sellers only to select for sale?
I do not want sellers to register products, but only select from products registered by the owner.
- January 8, 2019 at 3:07 pm #42693
Yeah it’s possible to setup using Single product multi-seller module – https://wclovers.com/knowledgebase/wcfm-marketplace-single-product-multi-vendor/
- January 8, 2019 at 3:46 pm #42694
Rafael
GuestVery thanks for the quick response. But there is the possibility of the seller who copied the product, do not change anything in it and also can not register new products.
The idea is to have a central control of the products by the owner.
- January 8, 2019 at 4:36 pm #42701
It’s off course possible to disable “Add Product” for sellers.
Now, when they will copy such a product for sell it’s in “Draft” mode. At that time sellers may edit this but will again publish in site after Admin’s approval.
Again publish product will no more editable by seller.
- January 8, 2019 at 5:00 pm #42704
Rafael
GuestIs there a way to create a panel where sellers can view all products and choose to click on the products they want to sell?
- January 8, 2019 at 5:08 pm #42705
MemberWell, off course possible. But this has to created using custom development.
Between, tell me one thing. Suppose you have created 100 products and 1 st vendor choose 10 from there, then next will have 90 in the list for select, right?
- January 8, 2019 at 7:32 pm #42720
Rafael
GuestNo, the same seller will have 90, since they have already chosen 10 of 100. But different sellers will be able to choose among the 100 registered ones.
- January 9, 2019 at 7:10 am #42773
OK, then when a vendor will choose any product it will be copied (duplicated) and will create a new product for specific to that vendor.
- January 9, 2019 at 1:34 pm #42824
Rafael
GuestI did not find the price of the Marketplace plugin.
- January 9, 2019 at 2:57 pm #42836
Cost for which marketplace plugin?
WCFM Marketplace plugin is free – https://wordpress.org/plugins/wc-multivendor-marketplace/
- January 9, 2019 at 3:16 pm #42840
Rafael
GuestWhat I was in doubt, no cost, is a free plugin?
- January 9, 2019 at 3:21 pm #42843
Yeah, marketplace plugin is FREE.
There has few paid addons for advance features – https://wclovers.com/addons/
But, your requirement is not there in any plugin, it will be a custom development.
- January 9, 2019 at 3:38 pm #42847
Rafael
GuestThank you very much, and sorry for the amount of questions.
I am accustomed to using another Marketplace plugin, which is paid and very expensive I would say, so I was surprised at the quality of the WC Lovers and still free.
Thank you again!
- January 9, 2019 at 3:45 pm #42848
MemberIt’s OK, I understand.
Yeah, WCFM marketplace module is totally free.
- The topic ‘Pre-registered Products’ is closed to new replies.
