Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Private Products not showing wc-frontend/products/
- This topic has 8 replies, 2 voices, and was last updated 8 years, 4 months ago by
- June 30, 2018 at 4:50 pm #25692
Jose Cisneros
GuestIm working on site that has to have all the products visibility set to “Private”, So that vendors can only see their own products in the shop pages, and it works great, when a vendor is logged in he’s only able to view his own products.
But in the wc-frontend/products/ private products don’t appear in the table, im getting this message ‘No data in the table’, is there a way to display private products also in wc-frontend/products/.
I will really appreciate your help.
- June 30, 2018 at 4:53 pm #25693
Jose Cisneros
GuestBy the way I’m using WCFM with WC Marketplace.
- July 1, 2018 at 6:02 am #25711
That’s right, WCfM does not allow to view Private Products.
Don’t worry, we will add support of this in next update.
- July 1, 2018 at 7:32 am #25719
Jose Cisneros
GuestHi Thank you very much for your reply. do you know more or less when the new update with this feature will come out?
Kind Regards, Jose
- July 1, 2018 at 4:51 pm #25736
New update will be there within 2 days.
- July 2, 2018 at 7:05 am #25787
Jose Cisneros
GuestGreat news, thanks. Keep uo the good work!
Kind Regards, Jose
- July 4, 2018 at 11:18 am #25866
Do you updated WCfM 4.1.7 and check this yet!
- July 9, 2018 at 10:39 am #26127
Jose Cisneros
Guestyes, working great!
thanks - July 9, 2018 at 10:44 am #26129
MemberThat’s great 🙂
- The topic ‘Private Products not showing wc-frontend/products/’ is closed to new replies.
