Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Problem with payments
- This topic has 7 replies, 2 voices, and was last updated 6 years, 1 month ago by
- April 24, 2019 at 8:43 pm #59248
Maksim
GuestHello! When withdrawing funds, an error occurs. In the logs I see the error “payment processing failed: PayPal Payout setting is not configured properly please contact site administrator”
I have a corporate account PayPal in Russia. I would like to know which payment method to use correctly – PayPal Standard or PayPal Checkout?
- April 25, 2019 at 7:52 am #59347
Please check at wp-admin -> WooCommerce -> Status -> Logs -> wcfm logs -> you will see exact reason for this error.
– It should be PayPal standard, but please be sure “Payout” is enable for your PayPal account.
- May 2, 2019 at 2:49 pm #60420
Maksim
GuestThanks for the answer!
I contacted PayPal technical support. I was told that the withdrawal of funds for sellers is possible only when the Mass Pay feature is on.
Did I understand PayPal technical support correctly?
But in Russia, the inclusion of this function is possible only with a turnover of over 10,000 euros. For us, this is unacceptable.
Is there any other way to make payments to sellers? - May 3, 2019 at 3:58 pm #60507
Opps! So, you can not use PayPal!
Is Stripe work for your country?
- May 7, 2019 at 9:03 am #61018
Maksim
GuestWhat is the reason I cannot use PayPal?
Is this related to PayPal itself or to the settings of your plugin?
About Stripe I will find out.If I connect Stripe, then buyers will have to pay on the site through the Stripe system? Or through this system is only the withdrawal of funds to sellers?
- May 9, 2019 at 4:26 pm #61441
– It’s due to PayPal restriction.
– You may use this for both the purposes.
- May 14, 2019 at 1:35 pm #62197
Maksim
GuestIs this restriction in PayPal valid only in Russia? Or now payments to sellers do not work anywhere through PayPal?
Paypal technical support tells me different information every time.What exactly do they have to clarify in order to understand is it possible for us to connect payouts to sellers through your plugin?
What data needs to be requested?
Api username, passaword, signature available.
Do I need to connect PayPal Mass Pay to our PayPal account? - May 16, 2019 at 9:46 am #62451
Well, PayPal has changed their terms recently, I am not sure it’s block Russia from this or not!
You require “PayPal Payout” has to enable for this withdrawal payout.
Please ask PayPal support to enable this for your live PayPal account!
- The topic ‘Problem with payments’ is closed to new replies.
