Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Problem with tags under Product creation
- This topic has 1 reply, 2 voices, and was last updated 6 years, 3 months ago by
- June 24, 2019 at 7:32 pm #69381
Service Agmondo
ParticipantWhen creating a product and I want to choose from most commonly used tags it comes out as a long list and is being controlled by:
.product_tags_ele, .wcfm_fetch_tag_cloud, .wcfm_add_new_category, .wcfm_new_tax_ele, .wcfm_new_parent_taxt_ele, .wcfm_add_new_taxonomy_form, .catalog_visibility_ele { max-width: 214px !important; margin: auto !important; display: block !important; margin-bottom: 15px !important; }
specifically the max width
if I change the max-width to anything else via Google DevTools it fixes it, but I can not override by adding to theme css. Also I have even tried hard coding in the plugin files, but it doesn’t make a diffrence.
Please advise on temporary solution and fix at next upadte.
You must be logged in to view attached files. - June 29, 2019 at 8:05 am #70193
Please add this CSS to your child theme’s sty;e.css –
#wcfm-main-contentainer .wcfm_fetch_tag_cloud{max-width:750px !important}
Please check after clearing your site caches!
