Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Problem with tax default option
- This topic has 2 replies, 2 voices, and was last updated 5 years, 4 months ago by
Lewis.
- April 6, 2020 at 5:05 am #115786
Lewis
I currently have several problems with the way taxes are managed.
At the moment, by default, taxes are applied.
But many of my sellers, thinking they don’t need to charge taxes, just don’t go to the “tax” tab
It would be nice to have the option to choose “none” as the default option, there is more chance that a seller who knows that he must apply the tax to his products opens the tax tab and then select ” taxable ”
ex. <option value = “none” selected>None</option>But it would be better if there is no option selected by default, something like this:
<option disabled selected value> – select an option – </option>
and that we can decide to make this field mandatory. This way we would be sure that the sellers have put the correct tax status since this could have legal consequences if the tax is not applied when necessary or have charged tax without having a tax number.Thank you very much for taking my request into consideration, you are doing a very good job, I bought the ultimate version and I intend to buy both of your mobile app as soon as you release the ios version 😀
With love,
Lewis - April 12, 2020 at 12:16 pm #118314
Please add this code snippet to your site for the purpose-
add_filter( 'wcfm_product_simple_fields_tax', function( $tax_fields ) { if( isset( $tax_fields['tax_status'] ) ) { $tax_fields['tax_status']['options'] = array( 'none' => _x( 'None', 'Tax status', 'wc-frontend-manager' ), 'taxable' => __( 'Taxable', 'wc-frontend-manager' ), 'shipping' => __( 'Shipping only', 'wc-frontend-manager' ) ); } return $tax_fields; }, 50, 1 );
In case you do not have child theme then add code using this plugin –Â https://wordpress.org/plugins/code-snippets/Thank You
- April 14, 2020 at 10:23 am #118925
Lewis
ParticipantThank you, the code allows at least not to put the taxable product by default. On the other hand, there is always the problem that even if I put the mandatory tax field, sellers can publish a product without looking at this field since it has a default value. Could it be that it defaults to something like: choose an option?
Thank you for your impeccable support
