Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Problem with viewing Vendor Store page
- This topic has 17 replies, 3 voices, and was last updated 6 years, 9 months ago by
- April 4, 2019 at 6:01 pm #56257
Lorienz
GuestHello,
I am using the plugin currently on our website, the problem is that after we tested the website by creating/registering new vendor, it was successful but we can’t view the vendor’s store page, like for example mywebsite.com/store/vendor-store-page/
It redirects us to shop/store page.
What seems to be the problem or issue, or have we not set the plugin right?Hope we get a response soon.
- April 5, 2019 at 4:17 am #56288
Lorienz
GuestI would appreciate any response for this issue please?
- April 5, 2019 at 6:36 am #56298
sdel_nevo
When you renamed your store page did you save the change?
Also you might need to reset the sites permalink structureSteve
- April 5, 2019 at 9:01 am #56301
Lorienz
GuestThanks for the response.
I didn’t really change the store page.
permalink structure is as usual.
But what do you mean by reset the site’s permalink? - April 5, 2019 at 10:01 am #56302
- April 6, 2019 at 8:24 am #56453
– What is your site permalink? You will see this from wp-admin -> Setting -> Permalink
- April 9, 2019 at 2:16 pm #56978
Lorienz
GuestI have thick that option already but still I can’t view any sample Vendors Stores I created.
Can you guys please check on it in the backend if I can provide you with the logins?
Also I tested to upload store image and banner if it keeps me getting an http error and uploading images failed.
- April 9, 2019 at 2:41 pm #56983
Lorienz
GuestLike this, when you try to visit vendor store url http://rivermarketdev.wpengine.com/store/testwebstore/
it will only redirect to this page: http://rivermarketdev.wpengine.com/shop/ - April 9, 2019 at 2:51 pm #56985
Lorienz
GuestThis reply has been marked as private. - April 9, 2019 at 2:53 pm #56986
sdel_nevo
have you set up any redirects in any other plugins?
going here http://rivermarketdev.wpengine.com/store redirects to here
http://rivermarketdev.wpengine.com/my-account/
I think http://rivermarketdev.wpengine.com/store should list your dealers if I have got it right
I’m not affiliated in any way to wclovers, I’m just a very happy user
Steve
- April 9, 2019 at 2:53 pm #56987
sdel_nevo
Participantsorry I should have said
that when I got to https://www.mydomian.com/store
I’m redirected to
https://www.mydomian.com/store-list
Steve
- April 9, 2019 at 2:58 pm #56988
Lorienz
GuestThank’s on your response.
But I don’t have any redirect plugin setup on the website. It’s a fresh build site with few plugins really.
- April 9, 2019 at 3:07 pm #56991
sdel_nevo
Ok, try disabling all the plugins with the exception of the marketplace plugins and try again
If it works, turn on each plugin separately and test, when you find the plugin that’s created the error, do not turn it back onAnother thing to try
Change your permalinks to “plain”
From WordPress dashboard – settings – permalinks
Then saveIf you have a caching plugin installed you should clear the cached pages
Does it work now?
If so go back to
WordPress dashboard – settings – permalinks and select “post name” then save
test the site again
Steve
- April 9, 2019 at 3:14 pm #56992
Lorienz
GuestHello,
I already did those steps but still doesn’t work.
But thanks for your response.Hope their support can help us fix this
- April 9, 2019 at 4:03 pm #57008
Lorienz
GuestThanks anyway.
I already sort the issue out.
- May 10, 2019 at 7:28 pm #61772
Alvaro
GuestCan you tell me how you solved it? I have the same problem. Thank you
- May 10, 2019 at 7:33 pm #61775
Please try this –
- April 9, 2019 at 4:04 pm #57009
sdel_nevo
Participantthats great
what was it?
Steve
- The topic ‘Problem with viewing Vendor Store page’ is closed to new replies.
