Problems with store page
Viewing 9 reply threads
    • #40561
      Jose
      There a many problem with the store page that you can see in attach:
      https://ibb.co/XjYyr5n
      About tabs, at the moment don’t have solution with that: https://wclovers.com/forums/topic/vendor-store-tabs/
      But it’s more important that I can’t see products every other one in the second row.
      Another problem are with that can’t see all columns.
      And the other are about, how can I see all product if before I use filter category, don’t have a way to come back to a general view.
      Regards,
    • #40562
      Jose
      Update, I have only two tabs active, About us and Review
      Just Review work fine, but still about us with problems.
    • #40631
      WCFM Marketplace 2.0.3 has just released and we have resolved Store page tabs issue.
      Please update yours and take a look.
    • #40655
      Jose
      Thank you, but still problems with:
      Please see the screen capture:
      Regards,
    • #40656
      Maalik Alexander
      I am having the same problem. When going to a vendors product page, it’s showing 1 product per row. Which makes you scroll down to see every product, i want to be able to see the products side by side, not under each other.
      This is a link to one of the vendor pages on the site
      https://mycrystalcleardeals.com/store/inspirational-factory/
      please take a look and let me know how we can fix this!
    • #40687
      Hi @Alexander,
      I can see store products perfectly, side by side -> https://ibb.co/CbBGQvx
      You are not getting this view?
      @Jose
      , can you please give me a store URL to check this. Please be sure you have updated WooCommerce Multivendor Marketplace plugin at 2.0.3
    • #40735
      jose
    • #40751
      Thanks, kindly add this CSS to your site –
      .wcfm-store-page.woocommerce-page ul.products li.product {
          max-width: 25%;
    • #40755
      jose
      Work perfect !! Amazing your support.
      Do you know why was necessary put this css ?
      Thanks a lot !!
    • #40758
      You re welcome 🙂
      To add compatibility with your theme’s product catalog template it’s required.
  • The topic ‘Problems with store page’ is closed to new replies.
