Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Product Attributes
- This topic has 8 replies, 3 voices, and was last updated 7 years, 1 month ago by
- June 13, 2018 at 6:29 am #24743
clevelook
Need help.
We know that Vendor can add an attributes for their variable products, but when I check in backend menu under “Product –> Attributes” I found empty and where can I find the attributes that the vendor made for their variable products ??
I want to put product attributes filter widget in the shop page.Thanks
- June 13, 2018 at 7:30 am #24744
There are two type of attributes –
1. Pre-defined Attributes
2. Product custom attributesNow, vendors are only allowed to create product custom attributes.
But at “Product –> Attributes” you can see only pre-defined attributes.
If you want to setup widget using Attributes then define some Attributes from “Product –> Attributes” and restrict vendors to use only those.
- June 13, 2018 at 7:33 am #24745
clevelook
ParticipantSo user/vendor should not add their own attributes then ? and should choose from that we set in pre defined attributes right ?
- June 13, 2018 at 7:52 am #24751
MemberVendors can define attributes but those are only Product Custom Attributes.
WC structure does not allow to define vendor specific pre-defined attributes, we are a bit limited in this case.
- June 13, 2018 at 10:32 am #24755
cleve
GuestSo we have to make any possibilities attributes for the vendor to use in order to be able to use it to atributes filter widget right ?
- June 13, 2018 at 10:46 am #24756
MemberYes, then you just define Attributes from Products -> Attributes and restrict vendors to use only those.
Disable “Add Attribute” from capability.
- June 13, 2018 at 10:50 am #24757
cleve
GuestWhat if there is an attributes that not yet covered by us ? So the vendor should ask us manually to add their needs ?
- June 13, 2018 at 11:16 am #24758
MemberYeah, they may use Direct Message for the request.
- June 13, 2018 at 2:47 pm #24761
I have written something wrong.
Suppose you have created an Attribute “Color” and added terms “Red”, “Green” and “Blue”
Now, if a vendor wants to have “White” that he can add himself, no need to request Admin.
But, if wants to have a new Attribute “Size”, have to place a request to Admin.
Please know me if you have any queries regarding this.
- The topic ‘Product Attributes’ is closed to new replies.
