Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Product disponible to all vendor
- This topic has 1 reply, 2 voices, and was last updated 5 years, 6 months ago by
Sayan Naskar.
- February 13, 2020 at 12:07 am #106874
sergiolucianoajr
ParticipantI want to use the WCFM in a quite different way. I want my Vendors to sell the products I create, and don’t allow them to create new products. I’m doing this because the vendors will have my products physically and will bill the customer creating a new order, and I will not use to sell online.
So, I want all my vendors can access the products in stock, to have the possibility to create an order with those products in their order panel.
Is it possible to enable the same product to all vendors?
- February 13, 2020 at 12:59 pm #106934
Sayan Naskar
As far as I can see you don’t need any of the features that are available to the vendors in our WCFM Marketplace plugin other than creating the orders manually from the vendor dashboard.
Is there any special reason, like some other vendor feature you want to use from our WCFM Marketplace plugin other than just creating orders by the vendors? Otherwise, you can use the shop manager to create the orders manually it will be a much simple process for just creating the orders.Let us know your detailed flow and capabilities of the vendors you want otherwise, using the shop manager role of default WooComerce can solve your requirement.
Thank You.
