Product – Enable Reviews as required
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Product – Enable Reviews as required
Viewing 1 reply thread
    • #16694
      Brad Z
      Thank you for the recent updates especially Enquiry! You guys are doing amazing work with WCFM! I just have one small issue:
      I have it set in WooCommerce – Products that Enable Review should be a required field but in WCFM, the vendors can still turn off the “Enable Reviews” checkbox on a Product page. Please advise of solution.
      Brad
    • #16696
      Thanks for get in touch with us and it’s pleasure to know that you have very much liked latest updates.
      I understand your requirement and here is the solution for you –
      function wcfm_custom_product_manage_fields_advanced( $wcmp_advanced_fields ) {
      	if( isset( $wcmp_advanced_fields['enable_reviews'] ) ) {
      		$wcmp_advanced_fields['enable_reviews']['custom_attributes'] = array( 'required' => 1 );
      	return $wcmp_advanced_fields;
      add_filter( 'wcfm_product_manage_fields_advanced', 'wcfm_custom_product_manage_fields_advanced', 50, 2 );
      Just paste this code in your child theme’s functions.php, it will convert “Enable Reviews” required field in frontend product manager.
      Please know me is this works for you or not!
      Shhiv
  • The topic ‘Product – Enable Reviews as required’ is closed to new replies.
