Best Multi Vendor Marketplace Plugin for WordPress › Forums › Product Vendors › Product images are not persistent
- This topic has 4 replies, 2 voices, and was last updated 7 years, 1 month ago by
Kegham Karsian.
- September 13, 2019 at 6:31 am #81413
Kegham Karsian
ParticipantWhen i add images to the products then click submit. It works fine. But when i try to update anything in the product as data after submission all secondary images of the product are gone and left only with the featured image.
I think this issue was supposed to be solved a long time ago when there as a conflict with Hide My WP security plugin. Is the issue still not resolved? Anybody else has this issue too? I’m using latest version 2.6.6
- September 15, 2019 at 2:11 am #81739
Can you please show me “Hide My WP security plugin” setting screenshot?
Well, strange part is that if this problem due to “Hide My WP security plugin” then it should happen for all images, not only “Gallery Images”!
I think it’s because of something else.
Between, what is your WooCommerce and WCFM version?
- September 15, 2019 at 8:32 pm #81829
Kegham Karsian
ParticipantHello
Regarding the hide my WP its the free lite version. We have just closed the XML-RPC access using code. Not the plugin.
But the strange thing as you have mentioned that it is only the products page. This video is a test using the admin. Not a test as a vendor. I still didn’t test it as a vendor.
You must be logged in to view attached files. - September 17, 2019 at 7:46 pm #82153
I already understand this.
What is your WooCommerce and WCFM version?
Well, XMLRP does not have any matter here.
- September 19, 2019 at 11:28 am #82392
Kegham Karsian
ParticipantHello
I seems like it was the Hide my WP plugin. I had to change re-change the /uploads and /wpcontent roots to its original state.
- The topic ‘Product images are not persistent’ is closed to new replies.
