Product Limit for Store vendors
Viewing 1 reply thread
    • #137980
      gp8332
      I am using the WCFM marketplace theme with Martfury theme. I want to konw what is that i will require to allocate only a limited number of product listings for a individual store owners. I want to start with minimum and then allow more they they behave and value the markeplace.
      Gautam
    • #138244
      Your requirement not so clear, You can set “Product limit” from the group level. (https://wclovers.com/knowledgebase/wcfm-groups-staffs/), when vendor upgrade their membership plan then they will add more products(as per new group capability) .
