Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Product limit on downgraded membership levels
- This topic has 4 replies, 2 voices, and was last updated 7 years, 2 months ago by
vanilladev89.
- July 10, 2019 at 6:43 pm #71868
vanilladev89
ParticipantHello
I am seeking a solution regarding the pay for product module and product limits. When a membership is downgraded and there is a difference in the product limit between membership levels, the vendors products stay active even though they are now under on their product limit.
Can you create an autonomous function that would edit the amount of the discrepancy from published to pending or something that would automatically remove the discrepancy amount from the market?
- July 13, 2019 at 8:30 am #72266
– Yes, we can change product status to pending automatically, but which product we will apply this rule?
- July 15, 2019 at 5:25 am #72510
vanilladev89
ParticipantHello
I have thought about your question and I think that my original request is not enough to professionally remedy the issue. I think that if a vendor account reaches the negative product limit, the system should automatically disable all product capabilities except manage, and add, show a notice that the account is not in good standings, show a button prompting the vendor to purchase additional space, and hide all products until the vendor fixes the product limit amount. As you know, this can be done by purchasing more space, upgrading membership, or deleting products. What do you think?
- July 17, 2019 at 4:58 am #72735
Well, then you just have to set “Expiry Rule -> Product Status” to Draft at WCFM Membership setting – https://ibb.co/cT9NmWX
Now, vendor has to re-publish his products again and they will able to do this as per current plan’s product limit!
- July 17, 2019 at 4:23 pm #72862
vanilladev89
ParticipantHello
Okay, very good. I will explore this option. Seems to me like the remedy for my request could be to make another expiry rule called negative limit rule for when the vendor goes into negative product limit yes?
- The topic ‘Product limit on downgraded membership levels’ is closed to new replies.
