Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Product Review Sync- Not Working
- This topic has 11 replies, 2 voices, and was last updated 7 years, 1 month ago by
Support.
- June 2, 2019 at 6:06 am #65505
Support
ParticipantHi there,
I’ve enabled Product Review Sync under Review Setting in WCFM but it is rating the vendor stores 0 out of 5 for the product review but from the original rating it is 5 out of 5 rating. Please see the attached photo, any help will be much appreciated.
You must be logged in to view attached files. - June 2, 2019 at 7:23 pm #65586
What Star Rating is showing for that review under “Product Review”?
- June 2, 2019 at 7:45 pm #65590
- June 2, 2019 at 9:55 pm #65602
Support
ParticipantAlso, is there a way to pull and update reviews?
- June 3, 2019 at 9:19 am #65684
MemberSorry, review sync later option is not there.
Are you using any other third party product review addon?
- June 3, 2019 at 10:45 pm #65788
Support
ParticipantOh okay, will there be a future option for pulling updated reviews? I think that, it will be an amazing feature to have.
As for the third-party plugin, I’ve added in Photo Review. I’ve temporarily disabled it to see if it was interfering with WCfM but issue still persist.
- June 4, 2019 at 9:12 am #65835
– Yeah have this in plan. Also Review reply and attachment option will be there!
Kindly show me screenshot for wp-admin -> WooCommerce -> Setting -> Products – https://ibb.co/vCWQJPd
- June 4, 2019 at 11:23 pm #65936
- June 5, 2019 at 6:53 pm #66080
MemberOK, setting is fine.
– Do you have created any new product review after disabling this plugin? Are you still getting the issue!
- June 5, 2019 at 7:55 pm #66096
Support
ParticipantThank you for testing.
It looks like it works adding new reviews while the Photo Review plugin is active or disable. It appears the issue is only getting/importing the existing review to the vendor store.
- June 5, 2019 at 9:00 pm #66123
MemberOK, that’s possible. Store review not support import yet!
- June 6, 2019 at 8:45 pm #66291
Support
ParticipantOkay, thank you! Hope to see this in the next update!
- The topic ‘Product Review Sync- Not Working’ is closed to new replies.
