Product Upload: Linked Product -> not displaying correctly
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Product Upload: Linked Product -> not displaying correctly
Viewing 5 reply threads
    • #132935
      Jasmin Kronewetter
      Sometimes, when I upload a product and use the “Linked” tab -> “Frequently Bought Together” I will select a certain product, but then a different one is displayed on the product page.
      Does someone know why this might happen?
      Also, I updated WooCommerce to 4.1.0 and noticed in wp-admin->woocommerce->status I have bold red notifications next to WCFM that the installed version is not tested with WooCommerce 4.1.0 – Could this be a problem, should I have waited with the WooCommerce upgrade?
    • #132937
      Jasmin Kronewetter
      Adding to the comment I made about WooCommerce 4.1.0 -> In the WCFM changelog, it is mentioned that with 6.4.10 the WooCommerce 4.1 compability has been added, so I’m just confused why I have that warning message in my settings (I have updated WCFM to the latest version)
      • #132962
        Keymaster
        You can use it without an issue. As mentioned in our v6.4.10 changelog, the compatibility is already added. Also, you can update to the latest v6.5 which will remove the warning as well.
        Thank You!
    • #132956
      Keymaster
      Which plugin are you using for the ‘Frequently Bought Together’ feature? If you set the ‘Frequently Bought Together’ from the backend (wp-admin), is the behavior remains the same? Please reach out to the author of that plugin for this.
      Thank You!
    • #132967
      Jasmin Kronewetter
      Hi, thanks for the super quick reply! 🙂
      Hmm strange – I have updated to 6.5.0 but still see the warning message.
      About the Frequently bought together feature, I thought that was part of WCfM’s offering as I have it in the Store Manager / Product Upload tabs (see image attached), and I never installed another plugin for it, but maybe it’s part of the theme I’m using… I’ll investigate!
    • #132977
      Jasmin Kronewetter
    • #133033
      Keymaster
      Did you find out the plugin that adds this field? Check your Plugins page. As you have found out the same problem exists when publishing from the backend (wp-admin) then it has to be the problem of the plugin. Or there might be a setting for this.
  • The topic ‘Product Upload: Linked Product -> not displaying correctly’ is closed to new replies.
